XK8 cooling fan - help please!
Hi Guys,
I have just gotten my car back from being repaired by a buddy after a front end collision.
The car now looks great again. The repairs were done by a lifelong body professionally & he has done a great job with everything that I can see. Because he was helping me out, I don't feel this issue is his to deal with..
A quick description of the damage - replaced parts: hood, drivers side headlight, power steering reservoir, core support, fan assembly, core support cover and bumper cover.
I am experiencing a problem with the cooling fans. They are blowing one of the 30 amp fuses located on the driver's side engine compartment. To be specific, the 4th fuse down on the left side of the below picture is what keeps blowing.
I've done a lot of research before posting this - read the related threads on this site, read the shop manual (most of the testing procedures are over my head) and I've looked at the wiring diagram (also mostly over my head).
Yesterday, when the car was hot, I noticed it heating up at stop lights and then cooling back to normal once it had airflow from driving through the radiator. At that time, I diagnosed the fact that the fans were not running and the blown fuse. Trying to diagnose this by myself, I have tried a few simple tests:
Since this problem surfaced, I have asked the body mechanic if he recalled seeing any other issues near the left front headlight cavity - he did not see anything else with obvious signs of needing repair/replacement.
I've only had the car back a few days, but I do know that when I first got it back, on one occasion I did hear the fans running after I turned the car off. The fans were replaced with used parts from 707AutoParts and at this point, I guess they are as suspect as anything else.
I'm pretty handy with mechanical stuff, have a basic understanding of 12v flow, not too good with amps & ohms and am hoping that you guys can give me a hand identifying where the problem is... I do have an electronic tester, but am really a complete novice at using it (including the settings) so please, if you can be descriptive about tests and patient with me, I will try to perform whatever tests need to be done to isolate and repair this issue.
Thanks in advance for all of your help!
Front End Damage
- unplugged the passenger side fan and ran the car while hot - same fuse still blows
- unplugged both fans and ran the car cold for a few minutes with the AC on - the fuse did not blow.
- plugged in the passenger side fan and ran the car cold for a few minutes with the AC on - fuse did not blow, fan did not kick on.
- plugged both fans back in & ran the car cold for a few minutes with the AC on - fuse did not blow, fans did not kick on.
- Inspected all of the wiring and connections that I can easily get to, including lifting up the fuse block in the picture above to look underneath - I can find no evidence of frayed wires that might be shorting out.
Ok, a new update. Since my first post, I have tried several other things:
1) reconnected the passenger side fan and disconnected the drivers side fan. I ran the car until it was warm without the AC on and as soon as the Fan Control Module got the signal the turn the fans on, the fuse blew.
2) I was able to watch as the fuse blew this time, and observed it to be a bright flash as it blew out. I guess it's hard to say, but I am assuming this is indicating a dead short?
3) I've looked for the Fan Control Module by removing the driver's wheel well access panel and also the lower cowl cover, but I am unable to identify the Fan Control Module. Even so, while these areas were accessible, I looked for any broken, frayed or pinched wires and could find none. I also saw no additional signs of un-repaired crash damage either...
So it now seems to me that I've removed each fan individually from the system and am still blowing the same fuse. What I don't know is if the passenger side fan will blow the fuse without the AC turned on, I guess that will be my next test once the car cools down enough to unplug the drivers fan and reconnect the passenger side fan. I am going on the assumption (probably wrong) that based on the owners manual indicating that there are (2) 30 amp fan fuses (#12 & #14 if I'm remembering correctly), that each controls one fan unless the AC is on? If that's the case, I'm wondering if leaving the AC off (thus not running the fans together) will allow just one of the fans to work?
Is my thinking correct that only one fan is typically the primary fan and the other only comes on with the AC? If this is correct, which is the primary?
Lots of questions - thanks in advance for any guidance.
Tom
Tom
The relay/module is a TALL looking unit.
Jaguar RELAY MODULE FOR COOLING FANS - LJA6702AA
https://www.amazon.com/Jaguar-Relay-.../dp/B00NB56WY4
The X308 uses the same part so find/borrow one and swap to see if the one you have is damaged.
bob
bob
I would locate the relay, and trace the wires from there. The fact that the fuse is blowing when the engine is up to temp suggests that the relay is doing it's job, as in getting the temp signal, and switching power to the fans.
Remove both inner fenders, and trace the wires across the front beam, behind the chrome grill bar, to the fans, and from the fuse box. It would be my bet, that with all that front end damage, and repair, there might be a pinched wire, or a screw put through the harness. The harness travels across that front tube, right on top, where all your damage looks to have been......My 2 cents.....Mike
Thanks for the replies... the advice is well received and seems to be validated by my latest "test." I replaced the blown 30 amp fuse, disconnected both fans and ran the car until it got up to temperature. I then pulled over and sat on a road where I could quickly get air flowing into the grill until I saw the slightest hint of the temperature gauge starting to climb above normal. I immediately got air flowing through the grill, (I did not allow the engine to heat beyond normal) and then returned home to find the same 30 amp fuse blown.
In my logic, this seems to eliminate the fans as the culprit, which also means that the problem lies between the fuse box and the harness plugs to the fans. Now that I know what the Fan Control Module/Relays looks like, I can advise that I did find that yesterday and found no obvious signs of damage or wiring issue.
Is there a way to test the Fan Control Module and the relays? This would have to be explained in layman's terms as I really am not a genius with an electrical tester!
Thanks again,
Tom
Thanks again,
Tom
Received 2,402 Likes
Ouch! I would have likely shed a tear.
Hi Tom,
Fuse #12 (30A) feeds the RH radiator fan directly, and the LH fan through the Fan Control module when the fans are running at half speed.This rules out a short-circuit in the RH fan as this fuse doesn't blow.
Fuse #14 (30A) feeds the LH radiator fan through the Fan control module, but only when the fans are commanded full speed. This is the fuse that is giving you grief.
Sooo, either:
1) The module is damaged.
2) There's a short on the Orange/Yellow wire that leads from the FCM to the Fan, or the fan itself is short-circuit. Your last test rules out the fan.
I agree that the nature of the fuse blowing you have observed indicates a short cicuit (or very close to one!)
The bit we're interested in is attached.
Are you comfortable checking resistance with a multimeter?
You should be able to get the prods into the plug on the FCM.
1) Disconnect the LH fan and measure between LF9-5 and the car ground. It should indicate a high resistance. If not, swop the multimeter wires around and re-measure. If still showing a short, or nearly so, then there's likely a pinched wire as Mike suggests.
2) Remove Fuse # 14, measure between LF9-3 and the car ground. Again, it should read high resistance. If not, swop the multimeter wires around and re-measure. If still showing a short, or nearly so, then the FCM has a problem as Bob states.
Hope this helps,
Mike
Hi Tom,
Sooo, either:
Hope this helps,
Mike
The following 4 users liked this post by michaelh:
Hi Mike,
Wow, this is exactly the kind of information I was looking for - thank you so much!
As an electrical diagnostics idiot, I do have a few additional questions that I hope don't sound too stupid...
1) Your test #1 states to measure resistance between LF9-5 and ground. Am I correct in my interpretation of the wiring diagram that LF9-5 is the connector on the end of the wires that feeds into the LH fan and that I should be checking an OY (orange & yellow?) wire for resistance to ground?
2) Test #2 states to measure resistance between LF9-3 and ground. Is LF9-3 the un-powered (fused) post in the socket where Fuse #14 seats?
3) Below is a picture of my multimeter. I've read the instructions for testing resistance, but they are pretty vague. Any guidance on what resistance setting would be correct and what "high resistance" and a direct short would look like on the display?
Thanks again!
Tom
Thanks again!
Tom
RyuTom
Resistance is measured in ohms, the upside-down U shaped character in the 6 o'clock through 8 o'clock positions.
Turn meter on. Set to 6 o'clock 200 ohm position. Touch the 2 test leads together. This represents a short circuit. Look at the display. It may show zero, it may show 0.2 ohms. Either way this is what you will see when you find your short circuit. (FYI, 0.2 ohms represents the tiny resistance in the lead wires themselves).
1) pull the fuse.
2) determine which side of the fuse connections is battery (12volts), which side is the circuit.
2a) set the meter to 20 volts 10 o'clock position. Turn ignition on. Put one lead on a bare metal bolt nearby put the other lead into the left exposed fuse slot. Do you get a 12 volt reading?
If so this is the battery side. If not try the other slot.
Now you know which side provides a path to the battery (12volt side). Turn car off.
Put test lead into other slot.
Turn back to ohms.
Place other lead on any nearby ground, like an exposed bolt, nut screw.
Measure resistance.
If it shows a short circuit (resistance =0) it is showing a short circuit.
If resistance shows open, or a very high number, that tells you the short is in a part of the circuit that is "not in the loop" or not connected right now. This can be on the other side of the relay from a circuit perspective.
I have no diagram in front of me, but I next assume that somewhere between the relay and the fan some part of the circuit is touching ground AKA short circuit.
Let me stop here and give you a chance to ask questions. I hope this helps.
Friend, I'm reading this on a small phone you may have said I forgot. Did you already proven the fan itself works ? I'd unplug a fan and measure the leads to ground. Does one fan show zero ohms on both leads? If so this could help you narrow down your search for the short's location. Unfortunately computer controls sometimes ground both leads intentionally when not in use.
Let us know. I could measure mine if you do find a ground ground on any of the fans connections.
John
1) pull the fuse.
Turn back to ohms.
Measure resistance.
John
The following 3 users liked this post by Johnken:
Hi Tom,
I can't improve in any way on John's instructions, and just another observation:
From your description, the fuse only blows when the fans are commanded to run. I've looked more carefully at the diagram, and you can ignore test 2 as I see that fuse #14 is only connected to anything additional when the fans are commanded to run at full speed.
You have ruled out a short in the LH fan itself by disconnecting it and still experiencing a fuse blow. This implies a short circuit somewhere on the line marked 9-5 on the FCM.
It could be one of the the suppression diodes inside the module (the symbol that looks like an arrow pointing upward with a bar across). My gut feel, though, is that the Orange/Yellow wire that feeds the LH fan is shorting somewhere.
Easiest way is to pull the plug on the LH fan and put your meter (set on the 200 ohm scale) probes on each connector. I've just checked mine and get no reading (=open circuit:- what you want).
I suspect that you will see a very low reading - less than 0.5 ohms. If so, then you will need to pull the connector to the FCM. If you continue to get a low reading, there's a short in the O/Y wire. If not, it must be the FCM.
Do swop the probes and re-check if you get a low reading with the FCM connected. The aforementioned diode could give you a false low resistance reading, depending on the meter.
Mike
P.S. John: One connection of the LH fan is direct to ground.
Mike
TPBachur (08-20-2016)
At this point I would take it back to the guy that fixed it. I assume he got paid buy your insurance for his work? The fans worked before the wreck, now they don't. Should be his issue to figure out. He should figure it out and bill your insurance as this is unforeseen work. I hear ya on the BEST guy ever thing but this is business I feel.
Mike - I will proudly post an updated picture of my repaired car as soon as I can!
BRGJag - I wish I felt like I could ask him to do that! The body mechanic (Jerry) is a friend who agreed to help me save the car from the junk yard by putting it back together for me. I bought the car back from the insurance company when it was considered a total loss. The deal was that I would buy all of the parts, and Jerry would do all of the work & paint for a set price. Because this issue goes beyond the scope of our original agreement, I just don't feel it's his issue to deal with.
I am a little confused with your fuse location. Look at the fuse chart I have listed for your car on Fig 01.3
Link http://jagrepair.com/images/AutoRepa.../jagxk2000.pdf
Also look at the fuse listing I have from the fuse chart 4-19
Link http://www.jagrepair.com/images/Elec...eLocations.pdf
Looking at the fuse sizes in your photo do not match what the charts show. I could be wrong but it is worth checking.
Orthodixie (07-10-2017)
