XK8 Door Adjustment
UPDATE:
Yes other door is OK but....
Car HAS a reported rear end collision. Consignee (a dealer who is selling for the owner) said specifically it was a bumper crash only and that there was no damage not fixed.
Obviously I'm beginning to doubt this. I have only given $400 so far and I am willing to withdraw if this is not resolved. Dealer said door would be fixed before I pick up but he does not have a mechanic or shop and maybe he thinks he can fix it when he can't, so.....??
As much input as you can give me this holiday weekend would be great before I return.
UPDATE:
I'd walk away from this car.
So many question marks, right down to a cracked dash (which IMO, was caused by that little rear end bump)
For what you're willing to spend, seek out a private transaction from someone with a history on the car.
There are 3 of them in my immediate area with all the dealer required servicing and low mileage for your price range.
Received 2,368 Likes
+1
The door sagging over an inch is a lot, although it could be that it's been removed and re-hung sloppily.
I'd want to see the car on an alignment jig, but I doubt the dealer will have the means or the inclination to do that.
If you're still considering it, at the very least you need to take a trusted bodywork expert along with you. Be careful.
Mike
Mike
I've never seen one of these cars with cracked wood. Bring it in to a body shop tomorrow. Unless I'm mistaken, every body panel has a label showing the VIN number, so you can see which ones don't match.
I had to jump back on here because nobody is talking about the hinge itself. My door drooped about the same and the problem was entirely in the top hinge. It simply had worn out. There was about 1/16 inch of play in it that translates out to about an inch and a half at the end of the door. It is an inexpensive fix to install a new one.
michaelh (09-05-2016)
The three cracks seem they may be more in the glaze more than the wood. Could sun do this? I though maybe air bag deployment might be reason but dealer says if air bag blown all facia would be replaced and panel would be smashed. Is this true?
#28
#30
#31
Michael,
Everyone here is giving you the best advice they can based on what they've encountered, experienced or what they believe to be true; however, it's impossible to say at a distance what issues the car really has. None of us would want to scare you away from what could be a great car, but we'd be more gutted if you ended up with a POS.
I wouldn't have put a 1" drop on a door down to a worn hinge, but I'm not an expert and I've learnt something new today (thanks, RJag).
You need to let a Jaguar expert inspect this car, or any other you may be interested in. Only then can you make an informed decision on what to do next.
Mike
Mike
#32
99xk8guy
06-05-2023 06:28 AM
