Xk8 door lock
The first step would be to remove the door panel and see if the arm that links the door lock latch to the interior door lever has slipped off. Each end of the rod has a plastic clip that may have broken and allowed it to vibrate off.
If it is a broken spring within the door lock latch, you can usually find used replacements on Ebay.
Welcome to the forum Ian,
The Door Latch has three operating rods:
Red goes to the interior door handle, blue and green to the lock and outside handle.
Other than one of the rods becoming detached, microswitches in the Door Latch are a known issue but are available separately.
As you mention "MoT", you must be in the UK. If the Latch or any rods are broken, used parts from a specialist Jaguar breaker will save you a packet.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
