XK8 Door lock will not disengage
Old 11-30-2022 | 03:15 PM
Julian Black's Avatar
Default XK8 Door lock will not disengage
Need help here please. Passenger door lock is not unlocking and is locked closed. If I push Fob button, driver door inside handle or key, the door makes noise as if unlocking, tries 3 times then stops, and remains locked, I was able to pull door panel off from inside, but cannot get door to unlock and open. 2004 XK8 convertible. Thank you
Old 11-30-2022 | 04:47 PM
michaelh's Avatar
Hi,
You've made a good start by getting the trim panel off
Take a look at this U-Tube video. It's for an XJ8 rear door, but it's pretty much the same. Starts about 6:10 - see what you think:
Here's a thread from chillyphilly which may help after you get things apart:
https://www.jaguarforums.com/forum/x...t-open-175483/
Julian Black (11-30-2022)
Old 11-30-2022 | 05:07 PM
Pistnbroke's Avatar
The mechanism is purely mechanical With the handle pulled out have you given it a good shoulder barge from the inside to push it open?
Old 11-30-2022 | 06:52 PM
Thank you, that is the video I followed. It's a good reference. Our XK8s have the actuator attached to the latch under a plastic cover. I was able to get cover off (just one screw with a very shallow screwdriver) and break off the actuator's hook/eyelet to the latch. Then I could unlatch the door. Took the whole thing out and the actuator was solid stuck! The repair will be easy, once I find just the actuator, otherwise is buying the whole latch assembly. And then 3 door panel clips (the 3 front ones where panel goes into side of dash, cannot help but get wasted)
michaelh (12-01-2022)
Old 11-30-2022 | 06:56 PM
Originally Posted by Pistnbroke
The mechanism is purely mechanical. When its doing its three clicks or with the handle pulled out have you given it a good shoulder barge from the inside to push it open?
Pushed and huffed like the big bad wolf after the piggies! The actuator "stem" itself was stuck solid, but its motor was giving it 3 tries each time.
FastCat85
11-13-2021 10:16 PM
Captain Bob 369
09-21-2021 01:16 PM
Spikepaga
05-07-2019 10:06 PM
Jon89
04-05-2019 02:23 PM
razorboy
10-05-2017 07:15 PM
Quick Reply: XK8 Door lock will not disengage
