XK8 Electrical Diagram URL
Good Morning All -
Found a wire in the trunk that is not connected and trying to research and understand. WTH!
The URL is broken: https://www.jaguarforums.com/forum/x...ams-faq-34890/
Can someone point me in the direction of the correct URL. Thanks in advance.
Thanks,
Becky Thomas
1999 XK8
Houston, Texas
Thanks,
Becky Thomas
1999 XK8
Houston, Texas
Received 6,326 Likes
Rthomas7 (11-22-2020)
Jagrepair.com is a great resource. You probably won't find the connection in the wiring diagrams. It is most likely the isolation transit connection that was used for shipping and when the isolator was removed the connector was just tucked out of the. The other alternative is a connector that has 12 volts on it when the ignition is on.This is an auxiliary connection.
A picture of the connector would be best for a definition of what it is.
