XK8 electrical fault
Old 12-29-2017, 12:01 PM
fmertz's Avatar
Received 1,512 Likes on 1,060 Posts
Originally Posted by steve xk8
The car is stuck in park in my garage and I cant move it as it wont start and seems to be unable to de-select park. I am not over familiar with these cars and at the risk of appearing daft here , is there a way of getting it into N so that I can move it and transport it to have the work done.
I'll say it again, all of this points to the brake switch. The switch informs the module to activate a solenoid to release from Park. If you put your finger in the general area of the shifter, you can feel it. You should be able to hear it in a quiet environment, too.
To force the release, you need to unscrew the plastic plug near the shifter. Once off, you can use something to force the release (screwdriver, key?). It is documented in the owner's manual...
steve xk8 (12-30-2017)
Old 12-30-2017, 04:42 PM
steve xk8's Avatar
Okay .The new starter motor is fitted and the car is purring again.
the voltmeter is now showing 12 volts with the engine running and about 10v with ignition on so its still low but the car starts up every time and runs 100% which is what matters most. I have 13.2 v at the fully charged battery terminals.
Many thanks for all the replies. I apprecate it.
I am now a happy bunny again and so is the owner at my local petrol station. ! !
The following 2 users liked this post by steve xk8:
Gus (12-30-2017), StuG (12-30-2017)
Phil Preece
10-17-2016 01:41 AM
97 Xk8 mayhem
10-08-2016 01:27 AM
JimC64
03-02-2015 08:07 PM
sjuraud
08-28-2010 02:11 PM
JimC64
09-10-2009 12:44 PM
Quick Reply: XK8 electrical fault
