XK8 engine noise, what is that?
XK8 engine noise, what is that? - YouTube
I can't figure out this noise. This is with or without serp belts. The belt tensioners are fine on the top side. The chains were tight and the cams are in alignment. No engine light, I have not checked the codes yet. Help please.
http://www.youtube.com/watch?v=xGaeK...ature=youtu.be
Not a mechanic here but I do notice that the sound seems to perfectly be in sinc with the white marks on the belt. Just an observation so possibly a good place to start? And it sounds like a squeaking. Something rubbing. I tend to notice any slight squeak either in or outside my car. You sure every bolt is tight? I had a bolt on my fan housing that was loose and when I tightened it, my squeek went away. Not the same sound but similar.
Did you check water pump? There's another youtube video with a similar sound and they all suggest water pump. "Engine Noise Jaguar"
Bent valves would cause the engine to misfire due to reduced/no compression in a cylinder(s) - that doesn't seem apparent here. Ancillary devices (water pump, alternator, etc.) won't make noise if the belts are off guys. It doesn't appear that the dampener is out of whack and rubbing the cover. Hearing the noise through the stethoscope coming from the cover means you'll be taking it off...
AP3 (09-03-2013)
99xk8guy
06-05-2023 06:28 AM
innzane
09-02-2015 10:08 AM
