xk8 fault code help....please
Old 01-17-2012 | 02:09 PM
Harry Birdman's Avatar
Default xk8 fault code help....please
Hi, new to the forum after buying a XK8 recently.
Since purchasing ive had a few problems, some ive sorted and some taking more time and may need help or sound advice please.
On experimenting with the manual side of the gear box the other day i have been experiencing an oil pressure problem, the gauge keeps fluctuating from normal to dropping to no pressure. Oil level appears fine. I believe maybe electrical problem over mechanical!?!
Also getting the following fault code on diagnostic machine - P1024 - feul pressure gauge open?? any quick advice please??
thanks
H
Old 01-17-2012 | 02:55 PM
WhiteXKR's Avatar
It certainly could be other things, but both those problems have the yellow connector on the main instrument panel in common.
Remove the wood bezel and re-seat that connector a couple of times. If that solves the problem, clean the contacts with some aerosol contact cleaner. Instruction for the bezel removal is here: Jaguar XK8 Instrument Cluster Bulb Replacement - YouTube thanks to Rev. Sam.
Alag (01-17-2012)
Old 01-17-2012 | 05:01 PM
Brilliant, will definately take a look at this option. hints and tips like this, is exactly what im looking for! thanks
Old 01-17-2012 | 07:00 PM
Originally Posted by Harry Birdman
.............. have been experiencing an oil pressure problem, the gauge keeps fluctuating from normal to dropping to no pressure. Oil level appears fine. I believe maybe electrical problem over mechanical!?!
H
Model year?
In addition to WhiteXKR's checks, it's worth looking at the oil pressure switch and harness connector next to the oil filter. This connects the ground input to the instrument cluster.
Old 02-02-2012 | 04:37 PM
2001 XK8
Ok thats something else to check thanks. Its an intermittant fault at present
philwarner
25
06-26-2021 06:43 AM
cissdm
05-03-2016 07:02 AM
rsperle
09-12-2015 09:37 AM
tonyforman
09-10-2015 08:23 PM
skadmiri1
09-09-2015 12:27 PM
