XK8 Front End Alignment
I just had the front rear lower Control Arms replaced in my 2001 XK8 and am now wondering about getting an alignment. Is this something best left to a dealer with all the special tools and knowledge or is it OK if a tire store, such as Les Schwab, gives it a try?
Schwab quoted $70
Dealer quoted $150 - $450
Will the dealer do that better of a job or are they blowing smoke and demanding a lot more money?
Thanks!
Schwab quoted $70
Thanks!
Received 2,193 Likes
it depends on the PERSON doing your alignment. Ive worked on Jags 16yrs and know what they like and what works best for handling and tire wear. Now if you just want a alignment sheet that shows all green, anyone can do that.
oh and what shape are you Upper front shock mounts in? they are often shot affecting camber and ride height. If theres any crumbling of the material around the upper shock stem then theyre bad. Of course most non Jagaur shops have little idea what are issues and whats not on the car.
I look at it this way, you want your heart checked out but you dont want to see a cardiologist, just your general practitioner since he's cheaper. Whats the better choice
SteveJacks (02-18-2014)
I can not comment on your dealers or otherwise but here in the UK you will get a similar quote or 3X plus the local alignment places but all that happens is the dealer waits for you to leave and drives your car next door to the place who quoted you the lesser price, I don't know any of our dealers who have the sort of equipment to do laser alignment and I am not talking about the simple tracking devices with a couple of laser pens taped to them even I have those but the places that have the full kit which costs a serious amount of money that need to work constantly and not just on a couple of cars a dealer may have in to check each week
Brutal (02-19-2014)
Brutal (02-19-2014)
I have read nearly every alignment post on this forum, and particularly have paid close attention to Brutal's posts and can't say enough about his insight. I had struggled myself with alignment within the green yet still wore out tires extremely prematurely, and with the knowledge gained, and some polite yet firm discussions with a local alignment/tire shop, I have formed a relationship to the point where the tech and I look at the car, the tires, and the "current state" alignment together, and work out a plan for the toe. The fact is, on the front, only toe is adjustable, and it affects camber, and if camber is really off as Brutal mentions, parts must be replaced. As Brutal has said many times, regarding the front, pushing out on the front wheels to simulate what the wheels do when driving (naturally toe out) and adjusting for more toe in to compensate for negative camber, is key. And on the rear, similar to front, toe affects camber to some degree (pun intended), so I toe in on the rear too. Shims can be installed to adjust camber in the rear, but too much negative camber on the rear also is a sign of worn parts. Bottom line, educate yourself, and involve yourself.
You drive to work on the road, not on a alignment rack. Look what the tires say not just the machine, and check for toe out under simulated forces the car will see when driving. Do this by pushing out to see where the toe falls. Merecedes has been requesting this to be done(presser bar) on their cars for decades and it works well to check on all cars. You dont need a special tool just long enough arms.
And thanks for the kind words
I have to agree with Brutal on this..... It is all very we'll keeping things in the green and having your XK sorted how Jaguar intended, but let's face it Jaguar does not know the roads you live down, what you need in the ideal world is a guy who does not only know how to use the machine but who can read your tires, unfortunately these guys are few and far between and a lot of places will not move outside the norm because it contradicts what there policy may say...... Good luck
Tubeviper, thanks for stirring this topic up. I have replaced upper wishbone bushings and ball joints and my shock mounts (shock bushings seem fine). I am preparing to get new front tires as mine were worn on the inside edges...I suspect from the shock mount issue? I have noticed when I have the car on a jack that now I can get NO play when I pull back and forth on the top of the tire (12 O'Clock) but I DO GET A LOT OF PLAY side to side (IE 1/8" inch or so) when pulling at 3 and 9 Oclock. But it all comes from the shaft moving at the steering rack (IE no movement at wishbone bushings). Anyone know if that is normal...should our wheels give when you pull and push your tires at 3 and 9 O'Clock?
Thanks, Jac
Thanks, Jac
99xk8guy
06-05-2023 06:28 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
