XK8 Front License Plate Bracket
The 1998 XK8 I recently bought did not have a front license plate bracket. I found one at Craigs Custom Mustang Brackets for under $60. They call it a Universal Bracket. It has a slotted mounting tab. I found a plastic fastener at the bottom center of the car grille which fastened to the fascia. I carefully removed the plastic fastener with a hacksaw blade, then slipped the bracket tab between the grille tab and the fascia. Then I replaced the plastic fastener with a screw and nut. The bracket kit comes with a removable mounting piece held in place with strong double-sided tape if you want to go that route instead.
John
near Baltimore
John
near Baltimore
John
near Baltimore
John
near Baltimore
sklimii (06-24-2022)
Xcellr8
05-06-2011 12:06 PM
