XK8 Head Gasket
Hello all,
I'm new to the Forum, and a couple of people have kindly suggested that I post my question here on the XK8 board, so here goes, and thanks in advance of any help or advice you can offer.
After 46 years dreaming of Jaguar ownership, I finally scrape together enough to purchase a 1998 XK8. 30 minutes into the journey home the coolant low light comes on, and having topped up with 4.5 litres of water, I finally get home. My local garage then informs me that the head gasket has gone.
My love affair is almost over as soon as it's begun, so 2 questions to the forum as a newbie:
1) Is it possible that a head gasket could have let go so quickly without the prior knowledge of the previous owner?
2) Can anyone recommend a Jaguar engineer in the Bristol (UK) area who could tackle the job.
All advice warmly received. Thanks in advance, Andy
bluebubba456 (04-26-2012)
I cannot answer your question about the head gasket.
Even if this was a private sale you still have rights, if you can prove the seller was aware of this condition.
Although several UK members frequent this site, there is also a .co.uk forum you can try as well. Who will be able to advise on UK engineers to try.
First off you should get another opinion to verify the diagnosis.
Was that 4.5 liters added all at once or in several fills?
If that was all at once, your coolant could have been so low as to cause an overheating situation and cause the head gasket to fail during your drive. When the coolant is very low, it's level could be below the coolant temperature sensor and may never even give you an overheating warning.
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Also this car has serious problems. See other posts by this member.
The low coolant sensor is in the overflow tank, so a just few ounces low would register a warning.
The coolant temp sensor near the top of the radiator level....if the coolant is very low (liters low) the temp sensor will be sitting in air, not coolant, because it could be too low to pump.
Low coolant warnings need to be checked on promptly. Most of the time it is a slow leak and no big deal...but it is a very fast leak you can have an overheat and not even know it.
I learned this the hard way on my wife's S-type. She called me and said she had a low coolant message. I told her not too worry, it was probably just a slow leak, as I had seen before. I told her to pull over if it even begins to overheat. Fifty miles later the engine was toast, and there was never any indication of overheating, except no coolant left in the car when it was finally towed home.
The XK8 is a low volume, high flow rate cooling system. With a total capacity of 9.5 litres, the reported addition of 4.5 litres represents a catastrophic loss. As WhiteXKR says, coolant loss needs to be investigated immediately as damage can occur very quickly.
More information is needed about how the loss occurred, over what period of time and mileage to be able to comment on possible cause or consequences. Blown head gasket(s) is one possiblity. How have the local garage arrived at the conclusion it's gasket?
No, restricted performance is only set with electrical or electromechanical failures in the ignition or fuel systems. So issues like overheating, low oil level or pressure do not trigger restricted performance.
Thanks so much for the helpful replies. Just to explain what happened, the engine coolant low light came on after about 30 minutes - i.e. 30 minutes after I bought the car! It probably 10 minutes later that I got to a garage to top up. I let it cool for 10 minutes before unscrewing the cap with a big sweatshirt - and there was a fair bit of pressure behind the coolant. I put about 1.5 litres in at this point.
The remaining journey was around 150 miles, during which the coolant liight came on a further 4 times forcing me to repeat the process and using the best part of a further 3 litres. Beacuse I was (by now) carrying water I was always able to stop within 5-10 minutes of the coolant low light coming on and kept a close eye on the temprature gauge throuhout but it never went above normal.
I thought it would have been a loose / leaking hose, but it was only when I took it to my local garage that he gave me the bad news having completed a block test. It looks like I'm looking at a big old bill to get it back on the road.
Stumpy, and Old Jag lover - thanks too for your comments. You're right that this is the car with gearbox judder too. I won't mention the ABS, traction control or stability control lights that came on during the trip home!
I have been well and truly mugged with an absolute lemon! Beware the perils of the smiling seller and the 10 minute test drive.......!
What is really maddening to me is that there is an oil temperature sensor, and according to JTIS, if the engine oil temperature reads too high the ECM substitutes the engine coolant temperature sensor!
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
aholbro1
08-05-2021 05:02 AM
FS[Western US]: parting out 1999 xj8 vandenplas
bavareze
09-11-2015 01:49 AM
1964Daimler
09-09-2015 11:20 AM
