XK8 - Hi Beam / Fog Lights Same ?
My owner's manual says: Dips (low beam) are H1; High beam are HB3; Front Fog Lamp (bulb) is an H3. But various posts and several lamp companies all say Fog Lamp Bulb is an H1. PIAA bulb chart says H3 first year (1997) but later are H1, so perhaps Jaguar changed and did not bother to correct the manual (mine is 2006).
I think I will order H1s and hope they are correct.
Thanks,
John
Thanks,
John
Huh? I am sorry, but that does not make sense to me (I do not understand).
You help a lot of people and give good answers so I do not mean to be disrespectful.
H1 plugs into a bulb holder, H3 plugs in somehow AND has a separate wire. The filaments are different (I think they run different directions so light patterns would be very different), the bulbs are different lengths. etc. And I doubt Jaguar would have made a Fog Lamp system that would require an adapter to somehow change an H1 into an H3. They would just use one or the other.
I am just a poor owner trying to figure out which bulbs to order so when I take it apart, I have the right ones to put back in, not wishing to take do it twice as it appears the Fog Lamp Assemblies are fairly difficult to get to.
Thread started out stating H1; he has same year as mine, I guess I will just go with that.
I wanted to check/confirm as it differs from my Owner's Manual.
Thank you,
John
Thank you,
John
That helps considerably. Thank you very much for that explanation and clarification; especially the pictures. I hope it was not too much work for you to make those photos.
I have ordered some H1 Long Life bulbs so I don't have to replace them too often as it appears to be a pain to do so.
Thanks again,
John
Thanks again,
John
rsa760041
23
09-25-2015 01:33 PM
