XK8 Horn Not Working
having the same problem as the horn works from the relay on to the horns. I am going to look into the horn switch next and then the clock spring. if that is ok , i'll start looking for a short from the steering column to the fuse box. good luck with your problem. if you fix it, let me know what the problem was.
What I found was that each winter my battery drains so I remove it and recharge it and then horn does not work. Last year I was able to trace to relay and by changing the relay is seemed to reset the horn. Happened again this year but have not looked at it yet. Let me know what you find out. Thanks
rwilcoxen (04-21-2017)
99xk8guy
06-05-2023 06:28 AM
philwarner
09-05-2015 10:05 AM
