XK8 Ignition Coil Question
Hi All,
My 2000 XK8 has a bad H ignition coil. I verified by moving from Cylinder 7 to 8, and I got bad G ignition coil. Is there any advantage to replace all coils, or will just changing the bad one be ok.
I ordered a set of 8 just to be sure. Also new Bosch Iridium spark plugs.
Much thanks,
Eric "erjent" Jordan
Much thanks,
Received 2,662 Likes
Given the age of the vehicle, and since there's no mention of the miles on it, it's best to replace all the coil units and spark plugs as a set. It's also a good idea to renew the cam cover gaskets and spark plug boss seals as they tend to leak oil into the spark plug wells can cause the coil units to fail.
Attached is the cylinder numbering schemes for the AJ-V8.
The following 4 users liked this post by NBCat:
Don B (12-20-2022)
Received 13,203 Likes
Hi erjent,
You'll probably be fine with the Bosch plugs, but just so you know, the original plugs were probably made by NGK, and some Jaguar engines don't like other brands of plugs.
For others who want to know the correct NGK plug for their Jaguar, check this link:
NGK Spark Plug Finder
Cheers,
Don
Cheers,
Don
The following 4 users liked this post by Don B:
