XK8 Manual transmission - Has/can it be done?
Silly question of the day - I'm looking at a potential $4.k ,or worse tranny job in my '97 XK8. I hate that slush box, but love the car. Does anyone know if a manual tranny has ever been mounted behind the AJ26 on any vehicle? Or if one could be? To me the biggest hurdle in getting a flywheel that can handle a clutch on there. Any thoughts?
Mark
Mark
Mark
Mark
Go to www.eapj.com. They claim to be the only one to have done it accorind to their website. Their car was in an the XK8 magazine compilation put out by Jaguar World magazine.
03_jaaag (05-20-2024)
XKRacer,
Yeah, the $12.k does put a damper on it. But what about the S-type V6 Diesel tranny you mentioned at one time. Has anyone pursued that option? I would think that would be a bit more straight forward. Unfortunately, even at half the price (optimistic) that would still be a stretch to handle.
Mark
Mark
Sure but you would have to find one and ship it over, which then does not make it a particularly cheap option and you have a second hand item you are taking a chance on, also technically I cannot see why the flywheel could not be adapted with the clutch but that would be a bit hit n miss as nobody has done it, I made my own flywheel with the twin plate clutch from a XJ220, not the best choice for a road car, a single plate sintered is more controllable. If you could use everything from the S Type it would also solve your release bearing issue to, I believe it is hydraulic which allows the use of a manual XJS pedal assembly.......
There is still lots of things to consider, like the clutch reservoir comes under the screen scuttle which makes topping up a pain so you then have to make it remote, the clutch master also interferes with the wiper motor.
The things I am telling you is what you need to over come if you was trying to do a "budget installation" and if you are a bit of an engineer and have access to lathes and mills you could potentially do a conversion for around $3k mark but then you have the electrical problems and I don't care what other people say but the XK ECU from a tuners point of view is a piece of junk and needs to be used as a paperweight on end up in the eBay bin like mine did, get a standalone system which will cost you another $1k, take a crash course on mapping and do it whilst driving with a laptop most standalone systems allow you to do this, they will come with a standard map which will allow you to get started, from then on you play.
It is when you have to rely on other peoples expertise the costs start to rise, which is when you end up with a big bill, I have said this before, it is why I never pursued a manual conversion, yes there will be some lunatics out there but once you consider the time and effort is not worth it as the cost is too high.
I was the first to manual a XKR engine over 15 years ago before Jaguar even did it, Jaguar actually used the same gearbox and clutch setup I did, I am not saying they copied my idea but great minds think a like maybe, I did put everything up on the net......
I am happy to share my info, I still have all the cad drawings for the flywheel and the bell housing, clutch, release housing.......etc
Gives you something to think about....
I found some old pics
Have a good Christmas
The following 4 users liked this post by XKRacer:
XKRacer, this looks like it must have been fun. I have recently been given a XJ 4.0 V8 which i am going to break unfortunately as the body is rotten. I have been looking for a while for a good engine for my Track/Race car project but since the mechanicals on my X308 are all good i was thinking about using this engine.
Is there any truth about the S-Type V6 gearbox working with the AJV8? I have a friendly local Engineer who can do all the practical machining work, unfortunately all i can do is the mechanical stuff and drawings.
I will probably get shot at this point since it is going into my Capri, however there may be plans to put into a Kougar Kit at some point if it works.
I am looking into Megasquirt to run the engine as i know the Jaguar ECM are going to give me hell. Any help would be much appreciated. This will be a budget build so the breaking of the car will help pay for most (hopefully) of the project.
I think the main problem is the computer. You may have to completely replace it with a generic off the shelf engine management system from someone like Holley ... and things like CATS and traction control still might not work right (nt to mention VVT).
I think it is more straightforward if you replace the engine too, here is a place that has a chevy LS and T56 swap kit with all the computer issues whorked out. I doubt you wll do a manual alone conversion for less money:
Jaguar Specialties
You could probably swing that for under $5k total if you went with a used Iron block engine and T56.
Jaguar Specialties
Nice, thanks for the info. I take it the flywheel and clutch etc need a bit of fettling to fit but otherwise are also ok to fit from the S-Type?
Sorry if you have covered this before but i like these sorts of challenges in life
I may have to do some more calcs on gearing but this looks like a big hurdle covered straight away
The transmission that they make for our cars is great. Try A1 transmission in phoenix , az
I purchased a remanufactured one from them for 2200. The transmission works great now. there was this planetary gear ring that always break in our transmission. I honesty believe that you might as well buy a new updated transmission which will cost you over 5000, or you can get your shell or what not, buy get the transmission remanufactured, Not rebuilt
Very useful info, i like the idea of custom flywheel. Just need to work out some weights. Don't want to make too light, although the car i putting it in is a track car anyway, maybe not too much of an issue.
Are you using an XJR engine? The engine in my X308 is a 4.0 V8 with VVT, although i pretty sure this will work ok with something like Megasquirt. I beleive the system is the simple two stage system which electronically opens a solenoid to allow oil pressure to make the swithch to advance the cam by 30°. I just need to work out when it does this, or i can just forget about it and loose a bit of mid range torque (if it becomes too complicated)
I was almost thinking about using the auto trans and try and convert it to use manual shifters like US B&M or hurst shifter etc, but use buttons on the wheel. However the electronics would mean i would have to try and adapt the Jag stuff, which looks alot harder to install into another car.
This manual idea is much better, and will be alot more fun.
Still doing alot of engine measurements, but i am suprised how compact the AJV8 is, should easily fit into my Std Capri engine bay.
One last question, does it have to be the S-Type 2.7 V6 TD box or will any S-Type V6 box work. Not sure if there are any differences? Also i take it the gearbox shaft sits central to the crank on the V8?
My track car was a XK8 with the VVT, I use an Emerald K3 and told the ECU to enable the VVT at 1900RPM
I am using an XJR engine for the XJS, I bought the whole car for £1000 so I got the engine and all the ancillaries I wanted to use including all the rads...... This does mean I will have a V12 going soon, rebuilt by David Marks I believe and not driven since, why any one would be interested in an XK forum is beyond me but you never know
And yes it has to be from the diesel V6 no other will fit
