XK8 Misfire
XK8 Misfire
I have a 1996 Jaguar XK8 that like many others is in poor health !
I have just refurbished the Gearbox Rotary Switch and on its test drive the car went into limp mode flashing ENGINE FAULT & RESTRICTED PERFORMANCE with the following codes P0352, P0353, P0355, P0358 & P1368
I have replaced the Coil Pack & Plugs
I have swapped Ignition Coil Packs with each other and no change
I have done a wire continuity test from the Coil Packs Plug to the Ignition Control Module Plug and all ok
I have done a wire continuity test for cylinders 5 & 8 from the Ignition Control Module Plug to the ECU and all ok
Battery is on a smart charger so that's ok
I am now at a bit of a loss and have run out of ideas, Any Help would be much appreciated
I don't suppose you know which capacitor would relate to the Ignition Control Module 2 ?
Thanks for the suggestion
michaelh (07-15-2023)
Received 2,400 Likes
^^ What he said.
If the DTCs don't change, then it could be the ECM, but it could also be a dud coil pack pulling the group down. Try disconnecting the coils on the affected cylinders one at a time.
Are you sure that the caps have been sorted on your ECM? The date codes on the ones I can see in your other post imply that they are orginals from 1996.
I imagine that only Denso will have circuit diagrams for these modules.
@RJ - it's a while since I've seen caps referred to as condensers
redzed
02-01-2010 09:37 AM
