XK8 Oil cooler
Did all XK8's have engine oil coolers?
It is hard to believe that a 256 ci aluminum engine having 8 quarts of oil needs an oil cooler. I don't race or even run it hard at all, I'm old now.
Yes, I'm pondering making an all metal loop and eliminating the problematic lines.
Well, I'm set for a thrashing so go ahead and lay it to me.
Jack
Jack
olddavidp (08-23-2023)
piper 888 (08-24-2023)
I will do a little research before I make it a winter project. Hope my scanner will tell engine oil temp. If so I will proceed with checking temp with cooler and then cover cooler to prevent it from cooling and check temp again. If oil temp is well within safe range I will then proceed to delete cooler.
Jack
Jack
From memory, a picture of a short U-shaped pipe like you are describing has already been posted on this forum. Check this post:
how-inspect-oil-cooler-lines-xkr-where-they-exactly-located
I've been doing a little research and have found the 4.2 AJ34 engine has an oil diverter valve between oil pump and filter that starts diverting engine oil to the cooler at (217-227 F) and diverts 100% of oil to the cooler at 246 deg F.
Today at about 80 degrees outside my son hooked up his scanner to the 2005 XK8 and we proceeded to the foot of the Blue Ridge Mountains (about 15 mile drive) then proceeded up the mountain pushing the car pretty hard without doing something stupid going from about 1400 to 2900 altitude in a few minutes. At the top the engine oil got too 203 degrees. I reached through the opening in the front bumper and held my hand on a worm oil line. This tells me 2 things. The engine never used the cooler and I don't see any need for one. Opening at 217 degrees could possibly keep the engine from getting as warm as it really should be to drive off moisture from the crankcase.
Any thoughts?
Jack
Any thoughts?
Jack
giandanielxk8
07-10-2021 06:24 PM
