XK8 Oil Cooler Repair
Has anyone ever had an oil cooler repaired?
Recently, the one on my 2003 XK8 developed a small leak, probably bit by a curb. I replaced the oil cooler, but I was thinking of taking the old one to a radiator shop to see if it could be turned into a useable spare. Is this worth a try?
How many lbs of pressure would the repair have to withstand?
What about using ‘a bypass pipe that was fitted to XJ8s’ to the XK8? Is this a practical idea? Has anybody tried it? If so, does anyone have a part number?
Thank you for the help…
Bob
Bob
Bob
Bob
If it is aluminum, then you need someone who can weld aluminum. It would have to be flushed first.
Or, you can try JBWELD after scrupulous cleaning.
The cheapest approach is to just clean it, bag it and stash it away for a rainy day without repairing it.
