XK8 oil dip stick
Billieg,
What Model Year XK8? I presume the dip stick isn't badly bent. Bad news for you is that it's a tough job getting to where the dip stick tube goes into the oil sump. Access is really bad!
The dip stick is probably fouling on something in the oil sump - maybe plastic bits that have fallen off the chain tensioners. Only way to be sure is to take off the oil sump and check.
jagosaurus
01-10-2013 12:55 PM
