XK8 Overheating
Old 08-09-2012, 09:45 AM
RJ237's Avatar
Received 2,799 Likes on 2,236 Posts
OOPS. I leave the cap off after starting, but only for a minute.
RJ
Old 08-09-2012, 09:48 AM
steveinfrance's Avatar
Originally Posted by GGG
With the coolant at the correct level (base of the filler cap neck) it will expand and spill over the top as soon as the engine starts to warm up. This excess normally goes straight into the Recovery Tank with the cap in place.
Didn't learn that today, but I shan't be repeating the experiment.
Fair does, makes sense, I'll stick to tractors. I've always done the same as RJ237 on other cars though.
Good news that it does look like the rad needed burping.
Old 11-19-2012, 05:50 PM
vettinrnd's Avatar
Guys I am experiencing g an overheating problem myself!the xk8 will idle at regular temp.as soon as you accelerate the temperature spikes! I am getting a code referring to air lock.What should I do next?
Old 11-19-2012, 06:36 PM
RJ237's Avatar
Air lock code? The ECM is more sophisticated than I thought. I would suspect a blockage in the cooling system, pump failure or thermostat not opening. The overheating problem I referred to recurred at idle and was definitely air lock.
Did you just drain and refill the system? That is when an air lock is likely. Please give the code.
Old 11-19-2012, 06:46 PM
WhiteXKR's Avatar
Received 2,985 Likes on 2,124 Posts
What is the code number, Pxxxx ?
Old 11-20-2012, 12:37 PM
oldmots's Avatar
Which tensioner did you replace, the belt tensioner? If so, did you route the belt correctly? If not, you may have a slipping belt and a slow, slipping waterpump. In some cases, the waterpump can be turned backwards if the belt is done wrong. I'm not sure that is possible with this car, having not tried it, but the loose belt is sure possible. It is also possible that the harmonic balancer has failed and is slipping, casuing th ebelt to act as if it is slipping.
Old 11-20-2012, 04:54 PM
RJ237's Avatar
Oldmots, vettirod does not mention replacing anything, just an overheating problem.
mikiep
12-20-2019 07:37 PM
CXJ
08-29-2017 08:41 AM
Pristine97XK8Convertible
04-28-2017 11:08 AM
vwbusbits
10-13-2015 03:43 AM
Johnken
10-02-2015 10:12 AM
Quick Reply: XK8 Overheating
