XK8 Overheating
With the coolant at the correct level (base of the filler cap neck) it will expand and spill over the top as soon as the engine starts to warm up. This excess normally goes straight into the Recovery Tank with the cap in place.
Didn't learn that today, but I shan't be repeating the experiment.
Good news that it does look like the rad needed burping.
Air lock code? The ECM is more sophisticated than I thought. I would suspect a blockage in the cooling system, pump failure or thermostat not opening. The overheating problem I referred to recurred at idle and was definitely air lock.
Did you just drain and refill the system? That is when an air lock is likely. Please give the code.
Which tensioner did you replace, the belt tensioner? If so, did you route the belt correctly? If not, you may have a slipping belt and a slow, slipping waterpump. In some cases, the waterpump can be turned backwards if the belt is done wrong. I'm not sure that is possible with this car, having not tried it, but the loose belt is sure possible. It is also possible that the harmonic balancer has failed and is slipping, casuing th ebelt to act as if it is slipping.
mikiep
12-20-2019 07:37 PM
Pristine97XK8Convertible
04-28-2017 11:08 AM
