Xk8 radio upgrade
Xk8 radio upgrade
I want to add bluetooth to my XK8. I tried the Parrott device but it only answers the phone and does not stream music, etc. due to the amp configuration. My installer suggested replacing the head unit, but I want it to look authentic. Has anyone found a single din radio fascia that looks nice?
If your Parrot supports audio streaming, it can be supported by adding an auxiliary audio input. See attachment.
This is another possibility: AUX-JAGCD Auxiliary input Adapter for Select Jaguar with CD Auto Changer :: iPod Adapters & Interfaces but they appear to be sold out.
Last resort is a direct wire such as described in this thread: https://www.jaguarforums.com/forum/x...-r-last-11943/
Has anyone had any experience with this device?
JAGCD-HF Bluetooth & Charging Kit for select Jaguar XK and XJ with CD Changer
JAGCD-HF Bluetooth & Charging Kit for select Jaguar XK and XJ with CD Changer :: Bluetooth & Streaming Audio
It advertises to be the aux input mention before, but also includes Bluetooth and a USB charging connection.
Any thoughts on the Discount Stereo product in general?
Any knowledge would be greatly appreciated.
I would be installed in a 2000 XKR convertible that to my knowledge has the original stereo equipment.
Thanks!
Thanks!
I just saw this review on-line.
"If you buy from DiscountCarStereo.com and things work they appear to be great BUT if the product is defective or fails in someway they want nothing to do with you. You will NEVER see a replacement product or your money back. Thankfully I was only ripped off $107.96; you could lose a lot more! Check the reviews (I wish I had) - they are poorly rated on many websites Stay away from this company."
Thanks!
Thanks!
I used a Motorola T605 to get streaming Bluetooth audio in my car, by wiring the audio in/out connections on it, into the CD player cable in the boot.
If you don't know your way around a wiring diagram though, the discount car stereo device does look like a much simpler plug and play way of doing it.
i've no experience of that unit either, (hey Nerja, is that you), though it seems to be an upgrade to its predecessor the P.I.E aux input adapter, in that it will only work if you have the premium amp fitted........ which i don't.
Also if there's a silent piece of music on the track, it reverts back to radio mode. so not ideal.
don't know if that new unit acts the same way.
i still believe the neatest cheapest simplest way of mp3's on the stock radio is with a versatile link and mp3 decoder board.
a decoder board will power up with the ignition on and continue playing the last track from when it last shut down with ignition off.
so it's fit and forget.
they're also amazingly cheap to buy. just $10 delivered from china.
best of all, its all automatic.
just get in the car, start the engine and your mp3's play instantly without you having to touch anything......ever.
no brainer really.
happy listening.
sossybaby.
no brainer really.
happy listening.
sossybaby.
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
