XK8 rear alignment camber
Re 2003 XK8
Looking thru a receipt for an alignment on an XK8 potential purchase. It said rear camber could not be set due to special shims required. Read the XK8 Bible sticky but no reference to this issue.
Could someone elaborate what these shims are? Are these special shims that must be Jaguar dealer sourced? Cost?
Received 4,285 Likes
shims can be purchased through the forum sponsors - SNG Barratts or jagbits - there are about 5 different sizes and are about $55 each. If the rear was lowered a 7 or 7.5mm shim would be needed to correct Here are a couple threads discussing the shims
https://www.jaguarforums.com/forum/x...er-shims-6005/
https://www.jaguarforums.com/forum/x...s-69356/page2/
if not tapered why not add washers to the flanged area to change the camber. 3.5 mm Shims are about 1/8” thick
randy
If you have a pick-n-pull junkyard nearby with XJ8's in it, these are a good source for shims, for a couple bucks. Its just takes laying on your back for 15 minutes and removing 8 nuts (4/side)
The shims are flat ground and go between the 1/2 shaft and 3rd member, lengthening the shaft and straightening the rear tire.
you cannot add washers due to the halfshaft seating surface. Read the threads I've included and it explains. The standard shim (I believe) is 4mm but you can replace with a shim up to 7.5mm. here is the SNG Barratts link
https://www.sngbarratt.com/us/#!/Eng...AFT%20ASSEMBLY
Received 2,192 Likes
The following 3 users liked this post by Brutal:
AlexJag
06-17-2019 11:42 AM
afonda
03-17-2019 07:43 PM
