XK8 Rear Alignment Shims
I recently had the upper control arm bushing replaced on my 2000 XK8. During the 4 wheel alignment I was told that I needed "rear alignment shims." My local Jaguar dealership didn't know what they were talking about.
Thanks for any insight you may have on this matter.
Rear shims on Jags are used to correct camber (the top of the tire leaning in or away from the center of the car) by spacing the axle shaft in or out from the drive flange at the differential. Typically unnecessary unless considerable spring sag, bushing and/or bearing wear, accident damage, etc. has occured. Even then, the root cause should be addressed before adding/subtracting shims takes place.
whm54 (12-24-2011)
Received 2,190 Likes
whm54 (12-24-2011)
+1. I have some rear alignment issues as well, with minor camber wear. I'll need a new set of shoes in a bit, and will look at the bearings and bushings then to see if it helps the camber issue. Mainly to help prolong tire life. The negative camber isn't hurting ride at all- a little more twitchy but excellent response. The alignment shop "recommended" shims, but dealer said they hardly ever do them and to essentially ignore the fix unless I REALLY was bothered. I'm not 2k bothered, that's for sure.
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
