XK8 rear parking sensor module
I am trying to find the rear parking sensor control module box. I thought that it was supposed to be in the boot (trunk) but I cannot see it. Perhaps I should look again more closely.
In the meantime is there anywhere else the module may be hidden? It is a 2003 XK8.
I have an intermittent fault on the sensors when in reverse so thought I would start with the wiring.
Alfred Grech (06-06-2021)
kstevusa (09-02-2023)
What failure mode do you have? Does the warning sound when it should not, or fail to sound when it should?
I had a fault of the first type, which ended up being a bad sensor. The two outboard sensors are easy to get at; the inboard ones require (I think) dropping the bumper. Lucky me, it was an outboard one. Found a replacement sensor on EBay.
99xk8guy
06-05-2023 06:28 AM
KarimPA
09-03-2015 07:32 PM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
