xk8 rear suspension which bushes to change
If you plan to keep the car for a good while then if I were you, I would bite the bullet and polybush all the way, having scrimped when I did my front end only to have to do it all again, I wouldn't make the same mistake with the back end.
Received 9,010 Likes
Don't know if any of these are any good or not, listed in the how to section
. Lower Control Arms
. Shimmy Cured by Lower Ball Joints
. Sway Bar Bushes
. DIY Upper A-Arm and Lower Shock Bushing Replacement
. Upper Shock Mount Replacement (DIY)
. How To Replace Upper Suspension Bushings in Video by Reverand Sam
.How to Replace the Tie Rod Ends in Video by Reverend Sam
. Sway Bar Bushes
