XK8 refurb Pt 2
Hi guys, got the oil changed today and added the restore product, reports to follow. There is a small amount of oil seeping out of the L.H rocker cover, last bottom bolt next to the firewall the awkward one, needs nipped up I hope. Was foggy and cold after the test drive so will have to wait until Wednesday. Have to say it went according to plan and was not that difficult, will check for leaks befor bolting the alternator air dam back on. Was very nervoius when taking him for the test drive after changing the tensioners and the oil, only travelled about 6 to 7 miles just to get up to temp and check things were in order, which they apeared to be apart from the oil issue.
The gearbox behaved very well apart from one minor bump early on, so finger crossed it continues that way for a long time to come.
Will try and change the drive belt on Wednesday too as that is in desperate need to be renewed.
Pics later on with update, as its to late now.
Cheers,
Arty
Cheers,
Arty
Received 6,332 Likes
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
Many thanks Graham & Norri, yes its a big step forward, but when you think doing nothing could well have destroyed the engine. Those plastic tensioners were probably only a few miles or trips away from failure. Thank heavens for a forum like this!
Pics from yesterday as promised.
First ones are of the front wheel well in order to check the suspension and inner wing section. I was very pleased to see it was in such good condition.
The second set are of under the car looking from the front to the oil filter, as you can see it is NOT a genuine Jaguar part, NOW it is!
Looking under the car, at almost 16 years old ( 16 end of this month ), its in pretty good condition. It needs a bit of welding near the seats area, the mounting area where I believe they normally get the metal worm, but quietly getting on with the job.
Thanks for all the advice and encouragement.![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Arty
Arty
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi RaceD are you referring to area in the same pic like yours? Just behind the strut? I will check again, but it looked fine on first inspection. I know this can be a problem area as well as the rear arches and examined them best way I could when I originally checked the car our when I bought it.
Fingers crossed........
Arty
JimC64 (04-03-2014)
Ahhhh, after re tightening the last bottom bolt on the l.h side it is still weeping. Must have the gasket on incorrect. Will have to wait until the afternoon tomorrow as my cls is in for its mot and a service. Would notmally do it myself but my friends garage has a special deal at this time 100 for service and test, rude not too. Fingers crossed it passes, oh by the way its blue too, wish the 8 was the same colour as its lovely.
Gave him a bit of heavy right foot tonight and was quite impressed.
ArtyH (04-04-2014)
Received 9,011 Likes
ArtyH (04-04-2014)
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
Good news, MOT pass and no advisories, a service all for £99.
Seriously good value, the foreman said the office staff had incorrectly quoted me, makes up for the £400 welding job they did on my sons Punto last year, you win some.....etc.
Arty
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
Took him for a drive this afternoon and after burning off the old oil, could not see any new leaks. Will check again tomorrow for any tell tale signs and leakage on the drive. I deserve a
![Icon Slap2](https://www.jaguarforums.com/forum/images/smilies/icon_slap2.gif)
I used some black mastic to stick the gasket in the rocker groove and applied a bit of black gasket sealer over the short length of cover from top to bottom.
Fingers crossed, there were no cuts so should be O.K.
Will check again over next few days.
Cheers,
Arty
Arty,
Good news on the MoT.
It looks like the gasket has been nipped at the two places arrowed in red. Hasn't cut so should be OK if put back in the groove and refitted.
Attachment 79093
Is that a crack or just discolouration arrowed in blue?
Attachment 79093
The bit you pointed out in blue is just poor casting and thankfully not a crack but well spotted, its a hole for the wiring to rest on at the back of the rocker cover so would not be critical for oil leak purposes, nice to know its in one piece though.
Thanks again for taking an interest.
Arty.
mikiep
12-20-2019 07:37 PM
Pristine97XK8Convertible
04-28-2017 11:08 AM
