XK8 serpentine belt problem
Okay folks, what do you make of this ? Accessory belt is jumping a bit. Only happens on the first cold start of the day. Then it settles down and is perfect thereafter.
The tensioner and the idler pulleys have been replaced, and the belt is new. All Jaguar OEM parts. In fact the tensioner was renewed again, in case the new one was the problem.
Before this, the car threw the belt once. One of the pulleys was noisy, hence the need to replace the tensioner, idler and belt in the first place.
Alternator is about 2 years old, the power-steering pump is about a year old. Aircon was switched off, and is the original unit. Water pump pulley seems fine, history is unknown, could well be the original. Crank pulley looks okay to the eye and is original.
All pulleys and bearings feel okay to the touch, so nothing obvious amiss really.
Car is a 4.0 XK8 with 92,000 miles
[youtube]isBMXplWhwE[/youtube]
The following 3 users liked this post by franksm:
I have 2 videos on my page with the same problem I ended up replacing the idler, tensioner and belt.
LovellyJubblies (08-10-2020)
On the bright side though, over the winter I added extra ground wires from the tail light ground planes to the chassis and that fixed the " rear bulb failure" message.
Forgot to post a reply on the new belt and tensioner.
IXLLER8, I ordered and installed an oem belt and tensioner. Tensioner p/n wasNCA7739AE , belt p/n was NCA2211AC. This seemed to resolve the issue. The previous tensioner installed by the repair shop was an aftermarket part and I don't remember for sure if the previous belt was oem or aftermarket. I did notice that when I removed the old belt by taking the tension off of the old tensioner and then when installing the new belt on the new tensioner, it took a lot more effort to move the new tensioner. The old one had about 9,000 miles on it. I wonder what the difference in the amount of pressure is between the two. Maybe the old one was allowing the belt to slip a bit or it just wasn't flexing correctly???
