XK8 smell and smoke when giving it some
Could there be a crack in the casting as i cant find the leak. There is more oil on the heat sheild and i cant see it coming from the cam cover gaskets but it must be unless there is a crack in the casting somewhere but its a pig to see.
I have had the cam coveroff twice now and the gasket and cover looks in good shape, could the case be distorted?
This time removing the cam cover i wanted it to be the last time so. I still couldnt work out how it was leaking with a new gasket and couldnt see a crack in the cover so i just cleaned the sufaces and put loads of dirko sealing compound in the corner near the leak and so far it hasnt leaked. So hopefully that has cured it. Not happy putting sealant there when there shouldnt need to be but it was my last resort.
#28
Attachment 94211
The pipe to the Atmospheric Recovery Bottle (arrowed in yellow) doesn't need plugging.
The harness lead to the Low Coolant Sensor (arrowed in green) is the only other item to be disconnected.
Dear Graham. Your photo with the green arrow is wonderful. I have a 2001 XKR. My connector (your green arrow) is floating, not attached to anything.
A new Expansion Tank comes complete with a Low Coolant Sensor and a Pressure Cap.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
