XK8 Speaker replacement
The grille and speaker can be easily pried up with a putty knife.
You can get a used speaker at Coventry West.
Jaguar Used Parts | XJ6 Jaguar parts | S Type | X Type
The Dash Mid Range and Door Tweeters were not supplied.
Over the years there were Many changes in the configuration of Speakers in the Standard and Premium Systems.
Received 2,192 Likes
I just send blown speakers(theyre not blown just the foam deteriates around the cone They buzz and rattle, and can be repaired) to allens speaker repair here in houston for speaker reconing. $40 good as new and dont have to worry about fitment of something else or buying a used speaker that may do the same thing tommorrow. Google speaker reconing in you city. Most large cities have people that do it
porkenstein (07-23-2011)
All the speakers in my '97 disintegrated so I replaced them with cheap Pyle audio speakers. The front ones came with crossovers, which I double sided taped inside the door, and tweeters that I mounted in the little triangular foam pieces in the corner of the door. I had to take the tweeters apart by removing the driver from the plastic mount, and it fit perfectly in the holder that's already there. Do a search on " Pyle PLG6C "
I used 4-way 6x9 ovals in the rear, but had to cut out the mounting plates to make them fit. They sounded great and I wasn't afraid to crank them when driving with the top down.
I am struggling with the alpine audio speakers in my 2000 xkr and found a shop is san Diego Sea level Auto Electronics 619 548 2641 that has some rebuilt factory speakers and offers friendly advice. After hunting down the speakers my auto shop refused to put them in so I Am looking for a shop in Miami for the instillation
Hey David, tried to send you a private message here but says you can't or have chosen not to receive them. It's about speakers. You can write me directly at Palmbeacher1@gmail.com
Ed
Ed
I replaced both rear speakers on my 2000 XKR convertible today and it was really much easier than I feared, The whole job took about two hours following the instructions from jag repair.com.
Dealer quoted $450.00 for labor only. They indicated hat did not show a replacement part number for the speakers, but I found some rebuilt from sealevel@san.rr.com This made instillation as easy as the came with the same instillation ring.
They also have dash radio adapter plates for older XJ's
Hey Miami guys....
I acquired a 2000 xk8 Conv last month. Just did a transmission replacement and some other service (with Rick at Gables Cats - expensive though good work...).
Seems all of my mid range speakers were blown except the driver side door, and now that one went too! Any help as to a shop or replacement speakers for my Jag? I remember a link somewhere here as to a website Site that matched up the oem speakers with certain Rockford Fosgate, but now I can't find the thread with the link?
Furthermore it would be nice to meet some local Jag enthusiasts....
KarimPA
09-03-2015 07:32 PM
