XK8 stuck in Park
XK8 stuck in Park
Greetings all! I bought a 1999 XK8 this weekend. The car is in very good shape, but has 101,000 miles on it. I drove it 200 miles all around town. Today I pulled the drivers window/mirror switch to fix a sticky mirror selector rocker. When I put it all back together, the car would not shift from park. The tilt switch now works only in the memory mode. Two unreleted issues?? I have played with the emergency brake, checked the brake light fuse and tried the rocking method with no luck. The foot
brake safety switch is physically moving with the brake pedal, but I don't know if is sound electronically. I am way in the country and would like to get the XK to roll./ Any suggestions or advise??
My S type is fine so all is not lost. Thanks, Dan
Welcome to the XK8/R world!
Yes, fuse 16 is most certainly the problem. At the top of the XK8/R forum there is a FAQ sticky where you will find the fuse charts for the car. It lists all the things connected to the fuse, several associated with the shift control. Also one associated with mirrors.
Rlover
03-30-2016 10:04 PM
neruda
10-18-2015 01:19 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
