XK8 Throttle Body replaced, Sensor Replaced Failsafe continues
Old 09-06-2017, 09:10 AM
dibbit's Avatar
Originally Posted by Gus
Do a herd reset then turn the key on for 5 seconds then off then on for 5 seconds then start the car. The delay in the key on off is to prevent the engine from racing on start up to 2000rpm. Hope that works for you.
I haven't heard of that procedure before - do you have more information on what it does?
Old 09-06-2017, 09:28 AM
kmeseck's Avatar
Default Thank You
I will try that and let you know how it goes.
Old 09-06-2017, 04:00 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
This will prevent the engine from racing up to 2000rpm on a restart after a hard reset. It gives the ECM time to reread all the cars components.
The following 2 users liked this post by Gus:
dibbit (09-07-2017), michaelh (09-06-2017)
Old 09-10-2017, 08:42 AM
Gus's Avatar
Gus
Gus is offline
Any luck yet?
Old 09-11-2017, 08:32 PM
JCam's Avatar
After installing the newly rebuilt toddle body, my wife's car was still acting up on occasion. It finally stalled on her in the middle of a busy intersection after idling in traffic. I had it towed to the shop and told them to fix what ever caused her to be in that situation. They tracked the issue to the fuel pump. After replacing the fuel pump, the car is running like it should. It was an expensive fix, but it is a small price to pay for my wife's safety.
Good luck!
Jamie
Old 09-13-2017, 09:25 AM
kmeseck's Avatar
No the car's thermostat is having issues. I have it at a repair shop right now. I let them know about the P0121 codes and told them not to replace or rebuild the throttle body. I am not sure if they will get to anything with that issue or not. I want the car back by this weekend for Colorado's English Motoring Conclave and rally this weekend.
34by151
05-06-2024 12:20 PM
09-02-2016 10:26 AM
09-01-2016 05:54 PM
dannio636
04-06-2016 10:59 AM
geewilicurs
04-05-2016 06:37 PM
Quick Reply: XK8 Throttle Body replaced, Sensor Replaced Failsafe continues
