xk8 timing chain tensioners
I have had two cars that had their tensioners changed before 50k miles . . . under warranty. One of them, a '00 had the tensioners changed at a little over 40k, a little over 80k and at 106k. All for good reason I assume. The 106k, with only 26k miles were both split a third of the way up when I personally changed them.
They all deteriorate, including the guides.
The secondary tensioner failures generally have the most disastrous consequences and sometimes come without audible warning..so these are a must.
The primaries and guides usually make an audible rattling as they deteriorate but generally do not cause the engine to fail disastrously.
Doing all is the best option, but if funds are tight at least the secondaries should be done.
yes, funds are tight now that i have yet another jag to feed green bits of paper to..
how easy is it to change those secondaries. I assume they are the "uppers" I can get to with just taking off the valve covers. apparently, you just zip tie the cam sprocket to the chain and undo the exhaust cam caps to lift it up enough to get the tensioners out. is that correct?
After reading the various posts on this subject, I bought a pair of the latest metal - bodied secondary tensioners for £75 and got all set to do the job: guess what, when I lifted the cam covers they had already been replaced, doh! So if anyone wants to save a few pounds, I'll pass them on for £65 including UK postage; they're new in the bags, never even been opened! PM me if you're interested,
Cheers,
John
Cheers,
John
99xk8guy
06-05-2023 07:28 AM
