XK8 timing chain, tensioners, water pump replacement
Old 08-22-2012, 08:04 AM
Bones28's Avatar
Thumbs up XK8 timing chain, tensioners, water pump replacement
Hello this is my first post, due to my 1997 XK8 overheating the other day, and a slight rattle from the timing chain when the car is revved, I am going to change the early parts that should have been upgraded. The engine is still the original, it has done 79,500mls had regular oil changes and various parts changed but no major services for a long time. Parts have started to arrive for the big job tomorrow. Let the fun begin.
Old 08-22-2012, 08:45 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Tony,
Good luck - odd idea of fun!
That'll keep you occupied over the Bank Holiday weekend.
Old 08-22-2012, 08:48 AM
Received 9,009 Likes on 4,113 Posts
Good luck Bones and remember we're here if you need us
Looking forward to your post.
Old 08-22-2012, 10:02 AM
Bones28's Avatar
Thanks it is nice to know help is at hand.
Old 08-22-2012, 12:53 PM
EZDriver's Avatar
Bones, the link shows my fun and a couple of solutions to problems you might encounter.
https://www.jaguarforums.com/forum/x...ics-how-52653/
Old 08-22-2012, 02:05 PM
Bones28's Avatar
Thanks for that, helps to know the awkward nuts first. I spent 3hrs in the burning sun last weekend getting the rocker cover off my brothers porsche, had to modify a good spanner. I have hired the tools so hope all goes according to plan.
Old 08-23-2012, 02:26 PM
Bones28's Avatar
Hi I managed to get the water pump off, just wanted to see if this had caused the overheating as I expected it had, none of the plastic blades were left.
Old 08-25-2012, 02:32 PM
Bones28's Avatar
Default Has not been fun.
Hi so far I have removed the water pump totally shot, the cam covers, cams look very good as do the tensioners and chains but they will all be changed anyway. I hope this will all be done tomorrow I have a bad back and this job is killing me lol. I have lots of photos and will get round to putting them up next week.
Attached Thumbnails XK8 timing chain, tensioners, water pump replacement-photo-1-.jpg   XK8 timing chain, tensioners, water pump replacement-right-ten.jpg   XK8 timing chain, tensioners, water pump replacement-right-cams.jpg
volkris (01-04-2019)
Old 08-25-2012, 02:46 PM
If you put the car up on jack stands it makes it a lot easier on your back.
Vector
Old 08-25-2012, 03:28 PM
Bones28's Avatar
Hi front wheels on ramps.
Old 08-25-2012, 06:58 PM
GGG is offline
Tony,
Appears you've captured all the bits of the pump impeller.
Engine is remarkably clean inside but looks like a bead of RTV on the top of the head as if someone's been there before you and not used new rubber gaskets.
Old 08-29-2012, 04:14 AM
Bones28's Avatar
Default Finished upgrade Metal Tensioners, 4.2 modified blades, Water Pump
Hi I have finished the upgrade of the timing chains tensioners, blades and water pump. The car started on the button and revved smoothly, but I think it is still in safety mode, not sure how i get it reset. I have not had a chance to drive it yet or replace the thermostat housing.
Attached Thumbnails XK8 timing chain, tensioners, water pump replacement-img_1175.jpg   XK8 timing chain, tensioners, water pump replacement-img_1172.jpg   XK8 timing chain, tensioners, water pump replacement-img_1176.jpg   XK8 timing chain, tensioners, water pump replacement-img_1177.jpg   XK8 timing chain, tensioners, water pump replacement-img_1192.jpg
Old 08-29-2012, 08:20 AM
GGG is offline
Tony
A good weekend's work.
Presumably the MIL was illuminated before you started? If so, you'll need to clear it.
Bones28 (08-29-2012)
Old 08-29-2012, 02:18 PM
Bones28's Avatar
Hi Graham
Yes the cars mil light came on and the low coolant warning as well as limp mode before I had a chance to stop.
Old 09-01-2012, 03:18 PM
Bones28's Avatar
I purchased a D900 code reader from EBay during the week, reset the codes today and the car is driving very nicely, I still have the top and bottom radiator hoses to change and the thermostat housing (I did put the new thermostat in) but want to drive the car for a week and see how it goes. The only thing that puzzles me at the moment is the heater does not seem to work, I will not get a chance to flush the system extensively till next weekend.
Old 09-01-2012, 03:26 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
I helped a friend change his tensioners and there was no heat, turned out to be an air lock in the cooling system. After driving the system took more coolant and the heater worked.
RJ______________
97 XK8 86K mi
Bones28 (09-01-2012)
Old 09-01-2012, 05:53 PM
GGG is offline
Did you fit the thermostat with the 'giggle pin' at the 12:00 o'clock position?
This allows any air to bleed. You can also speed up the process on a COLD engine by removing the Expansion Tank cap and repeatedly squeezing the top radiator hose.
Attached Thumbnails XK8 timing chain, tensioners, water pump replacement-thermostat-giggle-pin.jpg
Old 09-01-2012, 06:20 PM
Bones28's Avatar
Yes it was at the top, maybe a bit of water pump blade has gotten trapped in the heater pipe if that can happen.
Old 09-01-2012, 06:39 PM
GGG is offline
You look to have a large collection of broken impeller bits in post #8 but it's always possible some small pieces have been circulated. Most likely place to block in this instance would be the heater pump or valve.
Attached Thumbnails XK8 timing chain, tensioners, water pump replacement-heater-pump.jpg
Bones28 (09-02-2012)
Old 09-07-2012, 03:09 PM
Bones28's Avatar
Hi I have now driven the car for a few days, going on a long journey tomorrow the heater does work at around 70 mph, so next week I will flush the system, I am off on Sunday to buy a 300zx TT as a new toy and project, so I will have the time to finish the Jag. New headlining, XKR grill not sure what to do with the number plate I think they spoil the look of the car, was thinking of a stick on one for the bumper, I have had the bunper de badged.
Quick Reply: XK8 timing chain, tensioners, water pump replacement
