XK8 trickle battery chargers
We are getting ready to store our 2003 XK8 convertible for the winter. A friend of my who stores his corvette says he hooks up a trickle charge of some kind to his car to keep his battery up while it is stored (5 months).
He says he uses 1 charge that pugs into the cigarette lighter and on a different car he uses one that hooks up the battery.
Does anyone have any experience with any trickle charger that they would recommend while their Jaguar is stored for the winter?
Thank you,
John and Lin
Thank you,
John and Lin
John,
I've moved your question from X308 to XK8/XKR forum. There has been a lot of discussion on this.
My own choice is a CTEK which comes with a battery connection lead. It's been very reliable for over four years now. Was previously used on my XK8 and now on my XK.
JWheaton10 (10-31-2016)
I second the harbor freight charger. They are cheap and I have a lot of batteries to keep up.
Using the terminals under the hood works better than than charging from the trunk. That cover is unweildy to get to the terminals.
The hood open gives a good warning that the wires are attached when you get in to back out of the garage
I would spend the money on a CTEK.
Cheap electronics is more likely to fail, and failure can result in overcharging and a battery explosion (this actually happened to me with a Jeep and trust me, you do not want sulfuric acid all over your battery compartment). It is not worth the added risk for a few bucks.
I use the one of these :-
Solar Panel Battery Charger OBD ll Cable FREE DELVERY | eBay
with either a float charger or dedicated 12v car solar panel internal or external to the car.
the OBD connector has direct connection to the battery the cigarette socket is via ignition switch.
my charger is :-
YUASA-SMART-CHARGER-YCX-5-0-12V-5A-8-STAGE
hope this is helpful
my charger is :-
The following 2 users liked this post by dsd:
JWheaton10 (10-31-2016),
paul 737 (11-01-2016)
Received 6,361 Likes
I also have a CTEK (Multi US 4.3)
Received 2,266 Likes
JWheaton10 (11-01-2016)
There is a similar 12V terminal on both sides of the car.
The tiny amount of battery maintainer amps applied here won't hurt anything.
Don't charge the battery @ 10 amps doing this, however.
The following 3 users liked this post by Ungn:
I have used battery tenders for years. In fact I have one on my TVR right now. Haven't heard anything bad about ctek but Deltran is the "original". Easy to hook up perm. plug in the trunk that you can leave just the plug portion sticking up from the floor. Just be sure to feed the cord so it doesn't crimp on the trunk.
I also would be leary about using the cig lighter even though tenders limit the fuse to 7.5amp which should be fine for the socket over the long term I simply don't trust those wires being thick enough.
Last thing is if you have a lithium battery you need a charger that is made for those specific batteries as they have a different charging proceedure and can be destroyed by a regular lead acid maintainer.
The following 2 users liked this post by Ungn:
dsd (11-01-2016),
I have simply started reinstalling a spare lead acid battery for the winter months as who in their right mind wants to go out on a cold morning and stand there and play with the lights for a couple minutes to wake their battery up?
Great idea but they are a fail for real life usage. That said I did see someone mentioned Porkhaus is using them (and it helps 'em loose some of that pig fat!). That is the perfect application. A daily driver that spends time outside in weather "extremes" not so much.
