XK8 trunk lights
+1 on the lock mechanism. The mechanism has the micro-switches for the lights.
Here is a site where you can download the complete electrical manual for your car.
Gus has gone to great lengths to build the site for our members.
JagRepair.com - Jaguar Repair Information Resource
The following 2 users liked this post by avern1:
garycs (09-29-2015),
Orthodixie (11-24-2017)
Thank you for the help.
You are correct.
It is a micro switch in a plastic case with a plastic actuator that rides on the lock mechanism.
Unless I can get the part cheap (it should be cheap because the materials used in it are) my car will be getting a switch made in Malaysia but made to American specs!
Thanks again
Thanks again
Good news. Managed to get the below bulbs ordered, installed and all is working fine. These look like good quality bulbs and the blue colour works well.
https://www.ebay.co.uk/itm/262375550007
2X 42mm C5W 239 Car 8 LED Interior Festoon Dome Number Plate Bulb Light Blue 12V
In case someone is still having this problem......
The inline connector from the trunk light plugs to the grounding lug is a one-way diode designed to keep the trunk lights from being energized by any electrical system feedback should the micro-switch fail.
The connector is marked 91 AG 10374 BA and is available through your local Ford dealer under part # E9RY-10374-A at a cost under $20.00.
The micro-switch is part# LNC6242AB and can be found on eBay and other sources used for $25-$35. Usually attached to some part of the latching mechanism which can be trashed if unneeded. It was used on both the XK8's and XJ's from 1997 - 2003 (at least & probably longer). It is mounted inside a small black case that is pretty fragile so I just used a small screwdriver (or pick) to release the four latches (one at each corner) and then removed the switch. Replaced with working switch and then re-latched.
You can test the switch without removing it by finding the wire connector (12"+/- from switch) and running a continuity check with a multi-meter with the trunk open. No tone means switch is defective as the switch is in the closed (or ON) position with the trunk lid raised.
Johnken (11-24-2017)
99xk8guy
06-05-2023 06:28 AM
02jagstype
09-04-2015 08:20 PM
