XK8 trying to resurrect
help please i now have my xk on the road and running well BUT a couple of points i could do with some help with.
1 my local dealer is of no use whatsoever and i cannot get a code for the radio from them can anyone help with this ? last 8 of vin AR028706
2 roof will not work although it did before the garage reprogrammed car it will not work on door key or switch but hydraulics all test out ok which is the fuse to check as all pages i have found say that there are 3 fuseboxes (passenger door, underbonnet and rear but mine also has one in drivers end panel and i cannot find the fuse)
3 can anyone recommend a breaker as i need some interior bits ie glove box catch broken replacement carpets required and a couple of plastic panels
4 still need a reflector for headlight
thanks in advance
thanks in advance
ianmj (11-22-2015)
DON'T depend on the temp gauge in the car, that is a lame gauge and really only hits HOt/Red light comes on AFTER the car is about over heated. If you have a DROID phone download the Torque app and get the ELM Bluetooth adapter from eBay which will allow you to read the temps MUCH more accurately.
ianmj (11-22-2015)
I can't help with the first items from here, but for the smells hot please understand that the temperature gauge is really a glorified idiot light. It reads mid scale from 185 F to about 230 F, the jumps into the red as the engine is about to melt down.
Check that the fans operate when the A/C is on. If not that may be your problem. But you may have air in the cooling system, another cause of overheating, or more likely, the thermostat is not opening. That's a common problem.
ianmj (11-22-2015)
Most of the time all you need is proof of ownership and they will give you the code. I do not know this for sure but was told to use the last 4 of the vin number.
As for the heating issue the gauge in the car is a placebo so do not depend on it. If you have an infrared temp probe use it to verify the operating temperature. Have you checked your thermostat and water pump?
Gus
www.jagrepair.com
Gus
www.jagrepair.com
ianmj (11-22-2015)
i have now called droitwich jaguar they gave me the radio code with no charge which works great BUT i now have an issue with the roof the button does nothing and i cannot find the control fuses to check them all diagrams i have found state 3 fuse boxes one under bonnet one in passenger area ie end of dash and one in rear passenger area. my car has one each end of the dash one in the boot (trunk) and one under the bonnet (hood) where are the fuses please also i have tried to release the pump and operate manually but it will not budge HELP!!!!!!!
What year Ian ??? - wiring diagrams can differ depending on age of car. Worth putting in your "signature" - saves a lot of questions like this !!
Use Ebay for spares - there's always several XK8/Rs being broken in the UK. SimplyPerformace (Jon), CatKiller (Trevor) and Eurojag are regular sellers, all of whom I can personally recommend. SimplyPerformance can't be far from you - I seem to remember they are in the Oxford area. Got lots of stuff from there when I hit a deer at around 40 mph a year or so ago.
ianmj (11-28-2015)
This wiring diagram should help but it does sound link a fuse or relay problem.
Link http://jagrepair.com/images/AutoRepa...eline99xk8.pdf
ianmj (11-30-2015)
All the fuses that are part of the hood circuits are, I'm fairly sure, in the big fuse/relay box next to the battery in the boot (trunk)
There are five fuse boxes in total :
1 : Boot / Trunk
2 & 3 : At each end of the dash/fascia
4 : At rear of engine compartment - depends on RHD or LHD as to which side.
5 : At side of engine - just behind ABS control unit on left-hand side.
1 : Boot / Trunk
ianmj (11-30-2015)
ianmj (11-30-2015)
The feed for the pump motor is fuse #14 a 40a fuse however; it goes to the pump relays that are controlled by the security and locking control module. Fuses #12 & 14 are for the windows. Also the power to the latch and main control solenoids are from the security and locking module so for now all you need to check is the motor fuse and 2 (top up / top down) relays Page 24.
Link http://jagrepair.com/images/AutoRepa.../jagxk1998.pdf
ianmj (11-30-2015)
