XK8 trying to resurrect
thanks gus its not doing anything at all. I have tested the switch but by the time i got home from work today it was too dark to look at fuses but i am starting to worry that the bcm could be part of the problem this car is costing me a fortune but I will probably just keep spending as i do love my jags. I blame my dad for that he always had at least 1 jag at any time from the e type to daimler double six and xj12. i wish they were still in the family
OK a phone call is not an option.
The first thing you need to check and replace is the 40a fuse in the trunk fuse box fuse #14. This fuse is the feed to the pump when the relays are activated be the Security and Locking Control Module. If after replacing the fuse and the pump does not run then you need to unplug the power plug to the pump motor (2 wire White & Black connector) at the pump. When you do this use your volt meter and test for voltage at that plug. To do this you will need another person to push the roof open button and check voltage at the connector the White wire is power and the black is Ground. Tell me how you make out.
have changed the 40a fuse although it tested ok, with button pushed no voltage to pump wires at all and i have now discovered that with door key held clockwise nothing happens but with door key held anticlockwise the rear quarter windows wind down fully but will not raise again
What year Ian ??? - wiring diagrams can differ depending on age of car. Worth putting in your "signature" - saves a lot of questions like this !!
Use Ebay for spares - there's always several XK8/Rs being broken in the UK. SimplyPerformace (Jon), CatKiller (Trevor) and Eurojag are regular sellers, all of whom I can personally recommend. SimplyPerformance can't be far from you - I seem to remember they are in the Oxford area. Got lots of stuff from there when I hit a deer at around 40 mph a year or so ago.
#28
#30
#31
the roof was one of the few things that did work when i bought the car. I had a replacement bcm fitted to repair the starting problems not sure if they did anything with the security module but the car is now going back in on thursday to the garage who did the reprogramme as they admit they may have got something wrong in the repair. As for work done i have checked the motor runs if powered seperately , checked all fuses and even replaced the ones for the roof although they tested as ok, checked the switch wiring is connected and switch operates correctly, checked and cleaned all earths and manually opened the roof catch and finally changed all related relays. The most worrying thing is that I cannot even open the roof manually turning the key on the pump does not seem to release pressure at all and the rear windows will only do anything on the door lock and then only go down not back up but I am getting no power reading at all from the switch
#32
Ok let the shop look into the programming.
The roof will not open until the rams and roof linkage is unlocked so do not force it. I would suggest you go to my page and read a little about the roof operation just remember this car is not your father’s Buick so do not pull and tug in it. For the moment do a little reading and report back with what they find.
What I know now is that the windows operate the switch is good and that the pump motor operates and that you have no command from the security control module to operate the roof relays.
ianmj (12-06-2015)
#34
ianmj (12-07-2015)
ianmj (12-29-2015)
ianmj (12-29-2015)
#38
hi sorry for disappearing act but the car has been on hold for a few weeks due to other issues. Back to it now the garage say that the replacement bcm they fitted and reprogrammed was from a coupe not a convertible and now they are looking at it again they say that jaguar say this is one of the things that cannot be reprogrammed does anyone know a way of wiping the imbedded memory to allow reprogramming as a convertible?
#39
Note in the oneline that is attached that you have 2 relays that are controlled by the security module and that module also controls the valves that supply hydraulic to the latch & lift cylinders. The body control looks at the switches in the ram and in the header.
Are the relays getting control power from the security module to operate the relays? Also is power available to the control lead to the pump? You know that all could be good and you just happen to have a bad ground to the pump?? Use the volt meter and check for control power and power to the pump.
Link to oneline on the roof system http://jagrepair.com/images/AutoRepa...eline99xk8.pdf
Also use the oneline I provided on post #13
ianmj (12-29-2015)
#40
it gets better and better,,,,,, now the power steering rack has gone so just sourcing one of those now but as for the roof apparently the bcm fitted is not for a convertible and i will be very lucky to get one that will but jaguar can sell me one and programme it for only £1800. which numbers do i need to post on here for someone to tell me where to get the correct bcm? and still needing trim parts if anyone can help out
