XK8 in winter storage in MN
Hi, I have a '97 XK8. Awesome and I love it. I put it away for the winter today. So I put in a 16 oz can of Sea Foam in the gas tank. I put the car in my buddy's shed. Laid down a bunch of Bounce dryer sheets to repel the mice. Disconnected the battery. Covered the car with a nice cover. Put a blessing on it. Went out and drank a couple beers. Then moved on to wine. Did I miss anything? I would love any advice from any northern Jag owners on what they do when they put their baby away. Thanks in advance.
Received 2,263 Likes
Def. the Battery Tender. Spring start-up in the Nikisil engnes can sometimes be a problem. Hit me this year after 4 no-problem years. Gus is the man on the forum for the last word if you run into trouble. I would turn the engine over with the fuel pump fuse pulled until you see the oil pressure gauge go up, then replace the fuse and hopefully fire her up. Have a great winter.![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
PS: Brutal recommends Engine Restore with your oil changes to help with Nikisil compression problems. Good recommendation, his advice is too good to ignore.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Good advice from everyone.
I put mine away last month and with the mild weather so far I have had Jag fever, but today the temp was down to 10f above and wild chill -9. Back to reality.
Looking forward to spring!
Received 4,292 Likes
I'm still driving mine until snow really sets in. I'm getting married and moving early next year, so I'm hoping for a decent day around then to move the Jag to its new winter home. I'm going to need a new battery before winter storage, but I'll put my battery tender on when it finally has to go to storage.
Put mine away Thursday morning while it was nice out and before the snow started flying and the temp dropped Thursday afternoon. Forgot about the tires though.
If possible, you should try to fill the tank with non-oxygenated fuel. See the MN Street Rod Assoc. site for a list of stations:
http://www.msra.com/
per segelberg (11-25-2012)
