XK8 / XKR 4.0L Air Filter Replacement
Hi
Can anyone please tell me how to check the air filter on my XKR as I don't want to remove anything I don't need to.
I see there are about 3 clips on one side of the box and 1 at the back. Do I just unclip these and lift the box off or is there more to it?
Regards
Ade
Regards
Ade
I found a good way to "cheat" if the engine is hot, etc! That rear tab can leave your hands burning! You can pry the "snorkel" that goes from the air box into the right front fender away from the airbox, and use a small mirror and flashlight to look at the air filter while it is still in place. There is a small tab on the top and on the bottom of the snorkel that holds it into the box. Just push down and pry out. These filters seem to last 25k miles in typical conditions.
mhamilton
07-29-2016 12:22 PM
philwarner
10-23-2015 03:54 PM
