XK8/XKR - Non-OEM interchangable Parts Thread
Serpentine Belt Pulley Replacements - Exact fit. Dayco 89016
After having the plastic pulley and bearing fail on the serpentine belt spring tensioner on my '97 XK8 out in the middle of nowhere and having the car towed home I didn't feel like paying $100 plus for a new spring idler assembly with another plastic pulley.
I found a $19.99 (even cheaper online) Dayco 76mm metal pulley that is an exact fit for BOTH the fixed pulley by the alternator and the spring tensioner. Its Dayco #89016. These of course have the proper bearing already. Most auto parts stores seem to carry these in stock. Except here they all had just 1 in stock. The list price is $19.99 and as cheap as $14 with free shipping online. Just remember when removing the bolt that holds it to the spring tensioner that it is a LEFT hand thread unlike the fixed pulley. These do not have the lips like the ones on the early MY's had but they are not needed. So you can replace both pulleys and the belt for $60-70 total.
Dave
Dave
The following 13 users liked this post by DaveInVA:
Abby's Guy (02-08-2021),
arttomlin (04-04-2015),
Daim (04-23-2017),
eszpulecki1 (12-24-2021),
jimmiejag (04-03-2015),
and 8 others liked this post.
Hello Guys,
I live in Amman, Jordan and there aren't many XK8s around (the pfficial number is 8 in the whole kingdom!!) which is why I appreciate this thread sooooooo much.
This is a list of cars that use the same mass air sensor:
2000-2003 Jaguar Vanden Plas Exc. Supercharger
1999 Jaguar Vanden Plas
1999-2003 Jaguar XJ8
1999-2002 Jaguar XK8
2010 Mazda 3 2.3 Liters
2007-2009 Mazda 3 Turbo
2006 Mazda 6 Turbo
2010 Mazda CX-7 2.3 Liters
2007-2009 Mazda CX-7
2007 Mazda CX-9
2005-2006 Saab 9-2X
2004-2007 Subaru Impreza
2002-2003 Subaru Impreza 2.0 Liters
2008-2009 Subaru Legacy 2.5 Liters Turbo
2008-2009 Subaru Legacy 3.0 Liters
2004-2007 Subaru Legacy
2008-2009 Subaru Outback 2.5 Liters Turbo
2008-2009 Subaru Outback 3.0 Liters
2004-2007 Subaru Outback
2006-2007 Subaru B9 Tribeca
2004-2006 Subaru Baja Turbo
2004-2010 Subaru Forester
2008-2010 Subaru Tribeca
I used this info myself to get a hold of a used one for my Jag out of an old Subaru.
The most common one I came across (maybe OEM?) is Denso MB197400-3021, but there are others out there that fit all these cars.
2006 Mazda 6 Turbo
2007 Mazda CX-9
2005-2006 Saab 9-2X
The following 6 users liked this post by jafari:
akeno (06-24-2016),
CorStevens (02-18-2019),
GT'thusiast (03-01-2020),
Syb Drylst (06-17-2020),
t.flockhart (01-30-2024),
and 1 others liked this post.
In terms of water pump, the Bosch 96181 appears to fit the bill, and it also fits the following non-Jags:
• 2000 LINCOLN LS V8-3950 3.9L DOHC
• 2001 LINCOLN LS V8-3950 3.9L DOHC
• 2002 FORD THUNDERBIRD V8-3950 3.9L DOHC
• 2002 LINCOLN LS V8-3950 3.9L DOHC
• 2003 FORD THUNDERBIRD V8-3950 3.9L DOHC
• 2003 LINCOLN LS V8-3950 3.9L DOHC
• 2004 FORD THUNDERBIRD V8-3950 3.9L DOHC
• 2004 LINCOLN LS V8-3950 3.9L DOHC
• 2005 FORD THUNDERBIRD V8-3950 3.9L DOHC
• 2005 LAND ROVER RANGE ROVER V8-4398 4.4L DOHC
• 2005 LAND ROVER LR3 V8-4394 4.4L DOHC
• 2005 LINCOLN LS V8-3950 3.9L DOHC
• 2006 LAND ROVER RANGE ROVER V8-4394 4.4L DOHC
• 2006 LAND ROVER RANGE ROVER V8-4197 4.2L DOHC
• 2006 LAND ROVER LR3 V8-4394 4.4L DOHC
• 2006 LAND ROVER RANGE ROVER SPORT V8-4394 4.4L DOHC
• 2006 LAND ROVER RANGE ROVER SPORT V8-4197 4.2L DOHC
• 2006 LINCOLN LS V8-3950 3.9L DOHC
• 2007 LAND ROVER RANGE ROVER V8-4394 4.4L DOHC
• 2007 LAND ROVER RANGE ROVER V8-4197 4.2L DOHC
• 2007 LAND ROVER LR3 V8-4394 4.4L DOHC
• 2007 LAND ROVER RANGE ROVER SPORT V8-4394 4.4L DOHC
• 2007 LAND ROVER RANGE ROVER SPORT V8-4197 4.2L DOHC
• 2008 LAND ROVER RANGE ROVER V8-4394 4.4L DOHC
• 2008 LAND ROVER RANGE ROVER V8-4197 4.2L DOHC
• 2008 LAND ROVER LR3 V8-4394 4.4L DOHC
• 2008 LAND ROVER RANGE ROVER SPORT V8-4394 4.4L DOHC
• 2008 LAND ROVER RANGE ROVER SPORT V8-4197 4.2L DOHC
• 2009 LAND ROVER RANGE ROVER V8-4394 4.4L DOHC
• 2009 LAND ROVER RANGE ROVER V8-4197 4.2L DOHC
• 2009 LAND ROVER LR3 V8-4394 4.4L DOHC
• 2009 LAND ROVER RANGE ROVER SPORT V8-4394 4.4L DOHC
• 2009 LAND ROVER RANGE ROVER SPORT V8-4197 4.2L DOHC
and possibly a few more recent ones.
The following 2 users liked this post by jafari:
akeno (06-24-2016),
The fuel pump is ultra common, but the plastic harness isn't. Its a little fiddly, but you could replace the pump alone and install it into the original assembly.
I bought mine from a US car parts dealer, most of the cars it fits are Fords... etc. Perhaps the most common is the F150 1997-2004 and perhaps other years.
Jaguar parts
Car-Part.com--Used Auto Parts Market
#28
Hello Guys,
2006 Mazda 6 Turbo
2007 Mazda CX-9
2005-2006 Saab 9-2X
2006 Mazda 6 Turbo
2007 Mazda CX-9
2005-2006 Saab 9-2X
This is the part number 197400-2160.
The sensor also has this engraved on the plastic: L321.
The following 3 users liked this post by giandanielxk8:
What do you think about this ignition coil set:
2005 Jaguar XK8 Ignition Coil (Set of 8) at 1A Auto.com
Think it would be a waist of money? The price is cheap compared to any others I have seen of course $300 for the others recommended is not bad either.
tomfurie (04-28-2023)
#30
Sounds like a good deal.... Did you note that it is a Google Trusted Store? Nice to know if there is a problem.
https://support.google.com/trustedst.../1669761?hl=en
#31
If you only need one or a few, I've got 8 known good used OEM ones I'll let go for $20 each plus shipping.
#33
If you are changing the hydraulic fluid in your convertible top lift system, rather than using Pentosin CHF 11S, which provides one with an unpleasant-smelling "green shower" when a hydraulic hose in the windscreen header ruptures, Bilstein FeBi 02615 can be used instead. It is compatible with the system's elastomeric components and does not have a dye in it. You can buy it online or find it at good NAPA stores in the USA.
This, from the voice of experience. I recently replaced all the original Parker high-pressure hydraulic hoses in my car after taking a green shower. It was quite a painstaking job. Thanks to Klaus Witte at Top Hydraulics Inc. in Florence, OR for superior quality replacement hoses and the best support and communications I've received from any vendor in a very long time.
The following 3 users liked this post by Canuck pump engineer:
#34
Affordable Instrumount - FINALLY
$5.95 each (free shipping) About 1/10 the retail price of $50!!!!
At a minimum, we need these for our oil coolers and air filter boxes
This is an eBay seller, "Parts4export". Because any particular sale may have ended when go to look for it i won't bother listing the URL. But they call it a, Fuel Injection Air Flow Meter Mount.
Finally!!!
The following 4 users liked this post by scardini1:
#35
[QUOTE=Canuck pump engineer;1128527]The side marker bulb socket from a 2010 Ford F-250 is an exact replacement for those in my 2003 XK8.
Ford Part Number: F8RZ13K371AA
Here is a link to a source I found for only $7.10 USD:
www.group1autoparts.com/ford/f-250-super-duty/f8rz13k371aa/2010-year/xl-trim/6-4l-v8-diesel-engine/electrical-cat/side-marker-lamps-scat/?part_name=socket-left[/QUOTE ]
On my XK8 the JPT sockets on the rear markers are deteriorated and I found the item under the following link: AMP : Junior Power Timer | TE Connectivity
#37
#38
Fuel Injectors
I just had my injectors refurbished by Keith at "Injector Experts" (419-619-6650). $20 per + shipping. Great guy. Don't hesitate to call. O-rings were replaced as well as the screens. And you get a Before & After performance report card as well.
When I asked about alternate sources for our $200+ injectors, he said Subaru. Probably around $40. He didn't have the exact part number though. If anyone out there has the resources, could you update us with the Subaru part number? 80% off list, is a CHUNK of savings.
#39
2003+ XK8/XKR Fuel Filter Alternative
I was looking for a more reasonably priced alternative to the Jaguar OEM fuel filter 1X43-9155-AA/C2S20977 and found the WIX 33078 to be an identical replacement to the filter used on the 2003+ XK8/XKR's with the quick connects. It is made in Poland as well so I suspect t may come from the same plant. Its about $10.00 Attached are some pics for comparison. It has good flow specs too.
WIX 33078 Alternate Fuel Filter to Jag c2s20977/1X43-9155-AA
WIX to Jag Filter - Length Compaison
WIX to Jag Fuel Filter - Width Comparison
The following 3 users liked this post by athiker81:
#40
