Needed: 1999 XKR oil cooler (a huge speed bump tore mine up). I’m sure Jaguar would have used an existing cooler from Ford. Does anybody know what would fit?
I don't know about Ford parts, but the cooler on the earlier models is nowhere near as expensive as the one for my 2005. Someone had fitted (or there had been a parts-use-up order at Jag) an earlier model to mine, and it was leaking. Once I realized that the latter was shorter - less tall - (and therefore less prone to damage) and also less expensive, I replaced it with the same type.
If your car is similar, I don't think it will be easy to change the hoses / fittings. There is a rubber seal and special steel ends on the lines, and they are held down by elliptical hold-down plates trapped on the cooler lines, and having has a single securing bolt. At the time, I didn't realize this, and wasted hours trying to shop for the identical orientation, but those plates are free to rotate. This is important to know because some coolers have the securing bolt location oriented 'fore-n-aft, whilst others - mine - were offset at an angle.; the rotating design gets around that, as long as the tapped hole in the cooler is on the same 'bolt circle' as the original, which they seem to be (I concluded that on the basis of my 2005 having an earlier model cooler but yet no problem adapting to the hoses.
Also, I think that it will be difficult - impossible, probably - for the lines to accommodate a cooler of different width or mounting method. You can find replacement rubber Instramounts (Qty 4 reqd) at nowhere near astronomical Jag prices, if you are willing to shop around.
Somewhere in here I listed a very affordable equivalent to the Jaguar Instramounts. Try doing a search. They are a little longer than OEM and may need some coercing to fit, but they did the job.
I just replaced the electronics in my 2001 XKR's key fob (no longer working even with new battery, and the reprogramming procedure didn't help) with a $7 aftermarket key fob from eBay that's listed as being for Fords. I searched for the FCC ID on the back (CWTWB1U322) and the Ford ones came up, and after reprogramming it (instructions at https://www.jaguarforums.com/forum/x...4/#post1841806) it works just fine. Note that since I'm going by FCC ID, this may be a US-only option, unless your national (or EU?) standards body has a similar lookup number you can refer to. Also, this seems to be limited to the later key fobs with asymmetric keys; the earlier key fobs with all four identically-shaped buttons don't have this specific option unless there is a different interchange they can use.
My oil cooler leaked al ittle bit , so we decided to renew all hoses. After taking off the front we noticed, that no Jaguar cooler, but a Ford cooler was build in. Problem is, the hoses don't match. So i bought and installed a Jaguar cooler.
I want to keep my cat original.
Cheers !
Wolfgang
Hi All,
Here in the UK the high pressure pump for the headlamps washers, part LNA 7031BA, is only available from JLR Classic and the usual suspects for the same bargain price of £113+ tax. An almost identical pump is fitted to early Range Rover Discoveries and many other cars. I bought one, part no DCM 100560, from fleabay for £16 delivered and it works fine.
Be aware though, that some pumps on sale have more than 90° between the inlet & outlet pipes - these won't fit.
This $10.00 filter (or it's equivalent) is available at most auto parts stores. Use the codes FF677 and/or G6340 for cross referencing. Just cut away the plastic clips and it's a perfect fit. Should be be good for at least '03, '04 and '05.
The catalogs will steer you toward the threaded end filter (also in the pic). I think they're for earlier cars than mine, but I don't have the specifics.
UPDATE: my 2005 xkr fuel filter was factory at 77K miles.
a few trips to the autopart store and an exact match in size/ fit has been found.
WIX 33078 also... it is a 20 micron filtration.... this seems to be common.
R.D.,
That's great news.
Did you happen to notice if the water pump had Ceramic or Metal blades on the impeller (the early style had Ceramic then the late version had metal).
Thanks for the info!
This incorrect. Early impellers were Black Glass filled Nylon 66 and they got destroyed by the Dex-Cool Coolant. Jaguar changed to Black PPS then to White PPS. The Aluminum impeller ones are all aftermarket. None were ceramic.
Greetings, does anyone have a recommendation for a replacement micro switch? I have a 1998 XK8 (X-100) and need to replace a Burgess 9726 micro switch that is located on the Jgate shifter. It seems that they are no longer available and there are so many switches on the internet that look similar but look like they will require major modifications.
$5.95 each (free shipping) About 1/10 the retail price of $50!!!!
At a minimum, we need these for our oil coolers and air filter boxes
This is an eBay seller, "Parts4export". Because any particular sale may have ended when go to look for it i won't bother listing the URL. But they call it a, Fuel Injection Air Flow Meter Mount.
Finally!!!
I found a Jaguar Part Dealer in Austria selling it for 2,93€ plus shipping (though not so cheap from Austria). https://www.xkstore.at
search for EAC6805
Big thank you to all those that have contributed to this thread!
I just wish I had found such a forum in past years for other cars, may have saved me some cash . . .
Bill
Bill, from my experience, this forum, and the Jaguar owner's online breadth of knowledge and information sharing is far superior to that available with any other car. What these cars lack in aftermarket support, it makes up for in that aforementioned regard.
I was looking for a more reasonably priced alternative to the Jaguar OEM fuel filter 1X43-9155-AA/C2S20977 and found the WIX 33078 to be an identical replacement to the filter used on the 2003+ XK8/XKR's with the quick connects. It is made in Poland as well so I suspect t may come from the same plant. Its about $10.00 Attached are some pics for comparison. It has good flow specs too.
WIX 33078 Alternate Fuel Filter to Jag c2s20977/1X43-9155-AA
WIX to Jag Filter - Length Compaison
WIX to Jag Fuel Filter - Width Comparison
That looks like an ordinary Ford fuel filter. They were installed on about everything.
Some of the filters, like the one I found, have some kind of plastic interface on the tubes. You just cut the plastic off, and ta-da... - a Jaguar filter at a fraction of the price.
I don't know if this is the right place to upload this project, but since these are non-OEM parts, I am providing you with the latest addition to my xk8. It came without a pollen filter and now it is impossible to find one. So additive manufacturing is on our side.
For those who are left without a pollen filter and want to install it, I upload the STL files. Look at the total length, it is 432.5 mm. I say this because according to the program the file is interpreted in inches or mm, we will have to multiply or divide by 25.4.
I upload three STL: complete piece and in two parts to join with appropriate adhesive to the plastic used or by applying heat.
For installation, a gearbox casing screw (cut) is very practical.
Additive Pollen Filter Housing With filter
By the way, regarding the silembloc of the oil radiator, which appears in several threads, it is better not to put them and use a screw with an intermediate stop. The back and forth motion causes the pipes to become fatigued. Consult a hydraulic distributor. This distributor can also remake these pipes.
Thanks for this forum that is still alive.
