XKR 100 Glasgow - Engine Failsafe
Hi,
Can anyone help with my xkr 100 warning messages. It has Engine failsafe mode--cruise control not available--Incortrect part fitted, Took it to Jag garage in Paisley, He connected it to his computer and was told i needed a new brake switch and that would take it out of failsafe mode, No it didn't. Now been told all faults "COULD" stem from a faulty adaptive cruise control module. Any suggestions ?. Where could i get a Adaptive cruise module ? Are they expensive ?.![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
Any help would be very much appreciated.
Thanks Alex.
Thanks Alex.
Alex,
I've moved your question from UK Region section to XK8/XKR section. You'll get more views from members with the same model in this section.
If the garage gave you the actual codes and not just an explanation, then post the codes here.
If changing the brake switch didn't fix it it is probably the control module
https://www.jaguarforums.com/forum/x...failure-90835/
There are some micro-switches along the J gate path, they are reading where the shifter is. Any damage there can cause a lot of trouble codes. Check also the connectors. It was a recent post in Xj8 sub-forum about some similar messages.
Hi,
Thanks Alex.
Thanks Alex.
Is this business intermittent or there at every start??
Seen any peculiar action at the Climate Control Panel??
Cheers,
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Beardy
09-18-2015 10:00 AM
