Xkr 2001 , roof work
Hi tanngo, all you do is get in the car, put the key in the accessory position just before it starts, roll the window down and close the door. Then raise your window up and hold it in that position till you hear a small tick, happens after about 3 or 4 seconds on my car and presto! the window should drop when door pull is used. Repeat for passenger window and your done. Hope this helps.
-Tony
-Tony
don't forget to cycle down and hold the button till a click, then up and when closed, remain held down till a click 4-5 seconds sounds about right.
Is that what you're asking tanngo? The front windows do not drop a 1/2 inch when the door handle is lifted? And it does not seal back to the roof when closed?
My front windows don't go down either when I raise and lower the top, just the rear windows. If you look closely at my signature pic you can see that the front windows are up but the rear windows are down. I believe that is the way its supposed to work. Anyone else want to verify that?
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Beardy
09-18-2015 10:00 AM
