XKR Bonnets
They do sit a bit proud if you do it the way Frog has suggested and you will have to remove a cross section of the inner bonnet/hood panel.
I make carbon XKR bonnet skins which you can fit to an XK8 inner, not cheap, but again I can also make them out of GRP, you best/cheapest bet would be to find a breaker
User 070620 (08-06-2015)
They save a lot of weight, even the GRP ones are lighter, I must admit I have not weighed a standard hood as of yet but I will do it.
I carbon skin costs $500 and you will still need to supply a hood frame and the vents.
I have been toying with the idea of doing the vents to the later design, I did it on my track XK but not for the standard, a bit of a pain making and 'frenching' in the apertures, I did this hood as my plug all in steel before I moulded it to produce the carbon hood.
![](https://www.jaguarforums.com/forum/members/xkracer-70408-albums-race-xks-1975-picture-bonnet-hood-9750.jpg)
JagManBonano (10-05-2011)
You can find the vents on ebay.co.uk
As quoted by XKRacer
I suspect over the pond when you say they sit proud is that they set a little high on the hood the XKR hood has a recess for the vents so they sit down flush. Personally I wouldn't do it unless you flanged your hole so the vents will sit flush. Then you'd be looking at a repaint on the hood.
Sure wouldn't catch me doing it.
I can certainly understand the appeal of an XKR's power, but I happen to love my smooth, flowing bonnet lines. The XKR vents are a nice visual indicator of the great power underneath, but they don't make the bonnet look better, in my opinion.
JagManBonano (07-10-2013)
Not loving the lady lumps I got with my arden style kit from mina!! Although, I've had tons of good comments about them from admirers. Who knew?!?!?!
![XKR Bonnets-image.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/47678d1480968979t-xkr-bonnets-image.jpg)
