XKR convertible - Body stiffening?
I know this may seem like an odd idea but I am going to put it out there.
I have an 01 XKR convertible and I find that at times, the body seems to flex quite a bit.
This may well be normal for these cars, I am not sure.
I recall reading an article about how Mustang tuners will install braces in the engine bay to stiffen up the body on Mustang convertibles that have had engine & suspension upgrades.
Is anyone aware of someone having tried this sort of thing on an XKR convertible?
I know that it would likely involve some custom fabrication etc. and I am not afraid of that.
Look forward to your thoughts.
its been discussed, carbon fiber brace across the engine bay, but nobody has moved towards a prototype. There was a thread in the XK8/R section somewhere. I think it was a pic from either a mustang, or an aston martin.
Here's the image and the link to the site that manufactures them...
If you're inclined to do a little shop work, you'd be many-a-hero!
That shock tower brace is okay for corners but won't remove your flexing. Coupe Corvettes use an X brace bolted to the frame under the car to stop flexing when removing the top. It was standard from the factory for Verts.
I have sub frame connectors welded to the bottom of my SHO that REALLY stiffen everything up.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
