XKR Driver Seat Removal
i know i've seen instrutions for xkr drivers seat removal but can't for the life of me find it. help locating old directions or give new?
also putting together updates for brake switch replacement (what a back-breaker!)... if you'd care to put in 2 cents on that...
tks
dan314
tks
dan314
tks
dan314
tks
dan314
Here's a thread with a video. This car is an XK8, but the seat removal is essentially the same.
https://www.jaguarforums.com/forum/x...removal-71972/
Hi Dan ,
The trick I always use with the brake lamp switch is to tie a piece of cotton thread to one of the studs before you undo the second nut , that way you can guide the new switch into position with ease with an assistant pulling gently on the thread you have attached to the replacement , works every time .
However , you have already removed the switch so try and feed a length of thread through the upper hole and tie to the top stud of the switch ,
Hope this helps ,
Nik
Hope this helps ,
Nik
dan314 (05-06-2012)
Beardy
09-18-2015 10:00 AM
