XKR EGR Tube..replaced now second time?!
My 02 XKR had the TSB done in April 04 at 17kmiles which was about replacing the original EGR Tube with an updated and improved design.
So now, 7 years later and 56k miles LTD, I get that little bark on a cold AM start that is completely gone after 2 miles of in town driving. Take to muffler shop to upgrade to a better growl and ask them to find the culprit. They conclude it's some emissions EGR situation and suggest having the independent or Jag dealer swap out the offending part. For the sake of time and a ride home, I drop at the Jag dealer.
The updated EGR tube has split and it's $805 to replace. I hate my local dealer and their attitude, but succumb to a time for money equation.
They told me that it's not uncommon for these to fail even after TSB is done and that I should be happy the update lasted 7 yrs! Advisor said that depending on the amount of moisture that gets into the system will dictate the life span. It's been a Cal car since day one and spent most of it's life in BH/Santa Monica and now in SF Bay Area. Not a newb to playing with cars, but am I being taken for a ride?
Are others having a similar re-occurrence?
I'm with you in that I think it was unprofessional to make a comment like that to an owner, even if they did believe it. Personally, I think failure of that pipe has more to do with heat cycles than moisture. As far as a repeat failure...... I can't think of more than one or two that had to have a second pipe installed, though obviously it can happen.
Hope that helps!
Kiwijames (04-09-2011)
I'm sorry you feel you dealer may be taking advantage. I don't have the part price handy, but I can say that if you drove in with that noise here, locating the fault and replacing the pipe would run between $200-$300 plus the part. I'm sure labor rates are higher out west than they are here. It really is sort of a pain to replace that pipe on an XKR.
Hope that helps!
Hope that helps!
I'll say that as odd as some of the off the cuff remarks that can be uttered by dealer personnel , none will top the one from the Audi dealer when I brought in my TT years back for a recall, they told me I overpaid for a GTI in an Audi skin!! LOL..and I still have Audis in the stable!
I've found these forums to be a great venue to gather information and at least arm yourself when placed in front of a service adviser whom is comped on what he can sell you. I love the Million $ sales placard he has on the wall for 2010!
Thanks for perspective. Cheers
The price seems maybe a bit high, but not too far off given a couple of hours of dealer priced labor or so. The part lists for about $238, plus a few more dollars for gaskets.
In order to do this job, the coolant must be partially drained, and the throttle body must be removed and replaced with a new gasket.
Here is the TSB to give you an idea:
https://www.jaguarforums.com/forum/a...r-tube-tsb-pdf
Dealer off-the-cuff comments
The service writer at Jaguar dealer A.C Imports in Palatine Illinois told me to expect to pay $2,500 every year to keep the car on the road. "Not very reliable cars", he said, "Most of our customers just drive them to the country club in the summer". I think he really believed himself.
It's all relative. With the low prices of many of the used Jags, there are quite a few folks out there that bit off more than they could chew. The overall cost of ownership of a Jag is not insignificant....that said, it is comparable to other high line cars. The general public just needs to understand that they are not buying a Honda, or Toyota.
For example, factory hose with factory disconnects when generic hose with clamps would do quite nicely.
Those godforsaken "norma" connectors have a single purpose in life: quick assembly by robotics. Serviceability and replacement cost do not enter into the equation. Much of the component design of the vehicle can be understood once someone factors in the requirement of robotic assembly. Things that make you shake your head are all of a sudden understandable.
It can even be argued that maintaining *any* current era computerised vehicle is expensive if the owner insists on staying original.
Cheers,
Beardy
09-18-2015 10:00 AM
