xkr engine number
Received 2,632 Likes
xkrdave (05-07-2016)
Found this on the web. Not sure if the location is correct. My 2001 XK8 is near the water pump housing. Nearly impossible to see.
First‐Generation XK8 & XKR Chassis and Engine Numbers, 1997‐2006
Model Year Starting VIN** * *
1997................001246* * * *
1998................018108* * * *
1998.75...........024687* * * *
1999................031303 (ends at 042775)* *
2000................A00016* * * *
2001................A11051* * * *
2002................A24196* * * *
2003................A30645* * * *
2003.5.............A35155* * * *
2004................A36874* * * *
2004.5.............A40265* * * *
2005................A42348* * * *
2006................A44686* * * *
Engine Numbers ***
The engine number is located on a vertical rib on the left side of the block, just above the steering rack.
The number can only be viewed from underneath. Engine numbers are ten digits long and break down
as follows:
First and second digits: Year of manufacture* *
Third and fourth digits: Month of manufacture* *
Fifth and sixth digits: Day of the month of manufacture* *
Seventh and eighth digits: Hour of manufacture* *
Ninth and tenth digits: Minute of manufacture* *
If your engine number is prior to 000818xxx, it has Nikasil bores.
Engine Numbers ***
as follows:
I've been reading up a lot on Nikasil cylinders and it is really interesting. If you have it, you may not need to worry about it at all. Most of these engines (in the USA at least) are perfectly fine as our better petrol has had little sulfur in the early days. High sulfur content was ruining the Nikasil surface.
Nikasil was and still is used in some F1 racing engines and Porsche and others. It transfers heat more evenly, much harder than steel liners, makes for a much lighter engine, and has less friction which allows for a higher top RPM and more torque too.
The AJV8 is an engineering marvel. 440lbs, with superior cooling, lubrication, light weight, etc.
Always use the best fuel, the cleanest fuel you can find.
