XKR Exhaust Tips
I will definitely be replacing my entire system, from the manifolds back, but later (after other priorities are addressed).
Might be a LONG while, Skid...I've got the original system on my 1997, and it's showing no signs of trouble whatsoever. If you're going to wait for your back boxes to burn out, you might be driving a classic before you get those tips on.
Unless...Would the XKR quads would reduce the highway harmonic problem associated with rear straight pipes since the quads are quieter?
I could just eliminate the back boxes and run a straight pipe thru that area to the quads and not make any other alterations to the exhaust system.
Seems a simple solution!
#30
#31
I know where you can get a straight through pipe with a quad set up, the amount of sound difference is negligable, but yes they do sound a bit quieter. Not good enough to work instead of a resonator box!
#32
